Alum bellhousing
Discussion in 'The Garage' started by Muddytazz, Apr 10, 2007.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Anyone recognize this one?
  2. dyeager535
    26,982
    191
    Is this a trick question? :)
    Looks like a mechanical 465 bellhousing to me.
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    No trick question, just never seen a 465 fully enclosed bellhousing before
  4. dyeager535
    26,982
    191
    Aren't they all? Auto trans angled, typically thick AL cover, 465's thin sheet metal flat piece, gasket around the starter nose.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Look at the difference between the one up top and this one, there is no fully enclosed bottom on this one around the bottom of the bell
  6. dyeager535
    26,982
    191
    All the hydraulic (later) ones are fully enclosed, the open I expect is OLD.
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    So the one at the TOP would be a hydraulic bellhousing?
    Anyone else have any comments?
  8. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    That one is not aluminum :dunno:
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yeah i know that, but the one up top is and that is the one I'm trying to figure out cause I don't need it. Want to sell it but have no idea for what 465 its for.
  10. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Tazz, the upper one is the one off of the burban I gave you. it's off of a sm420 and has the lower half. Also the starter bolts on to the bellhousing and not the block like the later 465 version. All 465's I'v seen are fully enclosed and made of aluminum.
  11. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
  12. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    **edited* i was looking at the wrong pic. the top one you are inquiring about is off of a 465.
  13. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    The first pic you showed is exactly like the one on my truck (still the stock one).
  14. dyeager535
    26,982
    191
    I think it's all been sorted out, but just in case, the first bellhousing is not hydraulic. It's mechanical. Hydraulic would have the ear for the slave cylinder cast as part of the bellhousing.
  15. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    You can see the ear for the hydro slave here
  16. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I'd call that a 73-81 bellhousing or thereabouts.... since it doesn't have the extra holes that are used with the 4spd side-loader (OD) transmission ;)
  17. Phatsalmon
    Phatsalmon Registered Member
    May 1, 2005
    18
    West Palm Beach
    Same bell housing I have in my driveway waiting for my new engine to be delivered. It is off my 1984 K20 with 350HD and 4 speed trans and NP208 transfercase. I can send a picture if needed to validate
  18. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    491
    New Hampshire
    Looks just like my bellhousing...
    Mechanical 465, '84, aluminum
