Alumi-flex tie rods
Discussion in 'The Garage' started by bluehen, Mar 28, 2005.
  1. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
  2. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    Troy...
    that guy has some very interesting character flaws to say the least...
    He talks trash about some great fabricators in the business and has had some very questionable business practices.
    He's had some 4wheelers run into him on the trail and he was quite rude.
    As far as ALUMIFLEX goes... its basically t-6 aluminum (solid). Very light, very strong. I actually have a tie rod made of the stuff. Does it still bend? Yes... is it worth it? Yes. I'd save the money on the "alumiflex" and buy some t-6 rod and have it machined with flats and tapped for tierods. :D
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    bull... If they had some memory metal aluminum that could bend 8" and return with no distortion they'd be selling it for a hell of a lot more than that and everyone would want one.
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    T6 is a heat-treatment specification for aluminum; it has nothing to do with what the actual alloy is.
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    T-6 is a fabricators term for 60 series aluminum. 70 series is more rigid with less memory.
    Troy is a low caliber fabricator in the eyes of many of us AZ wheelers. He is also arrogant and rude. As Juan said just by some t-6 aluminum and be doned with it.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    bdozeraz runs one of those tierods. He says he loves it. He beats the hell out of it in the rocks and he said it is fine. I personally would avoid Troy at all costs. I do what was said earlier and have a piece of solid stock aluminum machined for tierod ends. I am sure that is all Troy does. It will bend if you hit it hard enough.
    Marv Springer runs solid aluminum links on his buggy and has bent the piss out of several of them.
    Harley
  7. jarheadk5
    Mar 6, 2000
    4,389
    PA
    While T6 may very well be a slang term for fabricators referring to 6xxx Al alloys, it is still an incorrect usage of the term. T6 is a heat-treatment specification, not an alloy. It means the Al in question has been solution heat-treated, then artificially aged by precipitation heat-treatment. Many Al alloys can be heat-treated to T6-spec; not all of them are suitable for use as suspension or steering links. If you go to a metal supplier and ask for T6, the first question you'll be asked is "What alloy?"
    Anyhoo, if you really want an aluminum tierod or draglink, good alloys would be 7075 or 7178. 7075 has a tensile strength of 77KSI and bearing strength of 139KSI. It's difficult to bend, and is also very hard. 7178 has a tensile strength of 84KSI and bearing strength of 151KSI.
  8. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Cant say anything about Troy, don't know the guy...
    My experiences with aluminum:
    6065- Bends and has memory. I didnt have much luck with it. It will break.
    7075- This is what I am currently running for all of my front and rear links and tie rod. I have had awesome luck with it so far. It will bend a substantial amount, but it always goes back straight. If you want aluminum, definately go for the 7075, although it is pricey.
  9. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    This thread got me curious so I did some digging and some calcs. I compared 1020 CR (common DOM alloy) 1.5" x .375" tube to 7075 T6 and 6061 T6 bar stock.
    _________Wt/ft_______YTS (ksi)_______Elongation at Break
    1020------4.517---------50.8---------------15%
    6061------2.070---------37.0---------------12%
    7075------2.163---------67.0---------------11%
    7075's Yield Tensile Strength is higher than 1020's, but it's elongation is lower. 6061 is a disaster looking for a place to happen.
    Not convinced, for ~2 lbs/ft I'd rather have mild steel's near infinite fatigue life.
  10. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    I am running one of his tie rods and it works great. I've beat the piss out of it, even pushed it back hard enough to make a crease in the diff cover and it came right back. As far as Troy goes you got to take him with a grain of salt. He is kind of full of himself. He gave me a pretty good deal on the tie rod cause I live just down the street from his house. I don't know what he regularly charges for them.
    Brent
    P.S.
    Just looked at the link. Beware I don't think what he is advertising there includes tie rod ends, so you will be looking at about another $60 bucks a side for quality ends.
  11. bluehen
    Nov 11, 2004
    215
    DE
    Thanks Guys... I appreciate all the feedback. My tre's are pretty bad right now, so I'll be doing something REAL soon. All that being said, looks like I'll just go with one of the tie rods from any one of the site sponsors. I wasn't concerned with the weight vs. steel. I came across Troy's website and was just curious about the product.
