Aluminium fuel line.
Discussion in 'The Garage' started by dodgetruck91, Jul 15, 2004.
  1. dodgetruck91
    dodgetruck91 Registered Member
    Oct 22, 2002
    99
    New Berlin, Wisconsin
    Hey, just looking to see id anyone hahs used that aluminium fuel line that jegs sells? it comes in a 25' coil and i want to run it in my truck.
  2. dyeager535
    26,979
    I know people run it, but from what I've seen, it's not a good idea.
    Aluminum will fatigue pretty easily. Besides that, anywhere it touches metal (frame, clamps, etc) it will corrode, which will weaken it.
    I believe your local autoparts stores should carry steel line that is hand bendable.
  3. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    I ran the 1/2" aluminum stuff (got it from either Jegs or Summit) for about 5 years with no issues. It's easy to shape and flare. The biggest surprise you'll need to prepare for it the cost of fittings. The fittings average $3~$4 each and it will take 2 or 3 pieces to make one junction so it gets expensive quick. I had feed and return lines on my truck so I easily had $150 in fittings only.
    I later found out that the aluminum tubing sold at refrigeration supply stores is basically the same stuff, cheaper.
  4. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    I bought my alum. fuel line for a $1 a foot. I never had a problem with it. I used rubber lined metal clamps to secure it to the frame every 4-5' and never a problem. Instead of fittings, I just hooked everything up with high pressure rubber hose and clamps.
  5. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Same here. /forums/images/graemlins/thumb.gif
  6. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i used it to plum my entire truck when i went to TPI. it was awsome to work with and i would recomend it. but it did use compression fittings and AN fittings on my entire system, it's a little pricey, okay alot pricey but it is real trick
