Aluminum diamond plate for firewall
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 55Willy, Aug 15, 2001.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I'm cutting a piece of diamond plate to cover the old firewall up on the Willy's. Should I use rivets, or monkey snot? I plan to seal the whole outer edge with silicon so water can't behind it. Any feedback will be appreciated
    <font color=red>It's not what you drive, but what drives you</font color=red>( Or is it what you work on,lol)
    <font color=orange> 1955 willy's on a 1977 blazer chassis </font color=orange>
  2. tyler t.
    tyler t. 1/2 ton status
    Aug 7, 2000
    163
    I would use rivets. Just my 2 cents.
    J:(P it's what's for dinner!
  3. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    hey, how hard is that diamond plate to work with??? I'm seen a couple people put that on the bottum of their doors etc... looks pretty sharp!
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    The stuff I have is kinda thin so it is easy to cut and work with. Just use a saber saw or jig saw with the right blade. later on I'm going to add a strip down the bottom edge of the body.
  5. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I'd definitely go with rivets or screws - we had an engine drop the big panel (glued) above the tailboard while running down the road - $300 and alot of cutting, fitting and swearing later, it's screwed on now.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  6. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    hey, that kinda give's me an idea... maybe I'll use diamond plate for the side panels in the back??? would it be practical for that???
  7. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    That'd look nice! I've seen quite a few fire department Suburbans with diamond plate side panels, and even a couple of Blazers.
    Dos mas Tecates!!!
  8. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    oh yea... man I'm gonna do that in Jedi Mind Trick! I'll get em chromed! (I'm pathetic! LOL)
  9. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    oh man I think I'm gonna do my whole truck, my house, my kids, heck lets do it all in diamond plate. Man everyone is on this kick now. It looks nice I would definetly fasten it somehow mechanicly.
    Like em big and topless
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I'm doing interior side panels too with it.
  11. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Just never use the stuff to make an engine housing - especially over a turbo. I've got that pattern permanently etched into my leg from getting it too close when the engine was hot - it only took fire apparatus builders about 30 years to figure it out.
    Dos mas Tecates!!!
  12. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    as a mechanic on aircraft i would say both.
    reason.... you have dissimalar metal. aluminum and steel. as they rub together with rivets it will scratch the paint off, gorilla snot will stop this. but it wont hold all the way with flexing over time. rivets will last a lot longer.
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  13. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Rather than "snotting" the whole firewall, you could get away with a couple coats of primer on the back of the diamond plate, and a coat of primer on the firewall. As long as there's no bare steel touching bare aluminum, you'll be OK from a corrosion point-of-view. Put a little snot on the rivet shanks before you put them in the holes to seal them, then snot the seams like you said you would.
    It's always darkest just before it goes pitch-black...
    [​IMG] <font color=green>Semper Maintenance!<font color=black>
  14. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Be sure to post some pics when you get done!
  15. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Alright, call me an idiot, but what is "gorilla snot"?!?
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
    Is it a bad thing when my reality check bounces?
  16. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Around here we call it monkey snot, it is an automitive adhesive used for trim panels and such. it is real messy and tacky.
  17. jarheadk5
    Mar 6, 2000
    4,389
    PA
    In the Marine helicopter community I work in, "gorilla snot" is polychloroprene adhesive. BUT, it kinda applies to any adhesive or sealant.
