Aluminum diamond plating for the rear floor
Discussion in 'The Body Shop' started by BlitzK5, Jul 31, 2005.
  1. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    Anyone use Diamond plate Aluminum for a rear floor replacement? If so is it strong enough and do you got some pictures?. Should I use diamond plate or stick with checker plate. I would think that Checker plate would be easier to weld but would rust alot easier and the Aluminum would last forever or am I wrong?
  2. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    I have a diamond plate deck built into my roll cage, and I don't think it's nearly strong enough by itself. I have aluminum framing welded under it for strength and if it also didn't have roll cage support underneath that framing every couple feet it would buckle. Maybe there's thicker diamond plate out there than I have.
    I don't know how you'd weld aluminum to steel at the edges... but I'm not a welder.
  3. tRustyK5
    Jul 23, 2000
    36,188
    1,393
    E-town baby!
    You can't weld aluminum to steel. It'd have to be bolt in or riveted...
    Any checker or diamond plate whether aluminum or steel comes in pretty much any thickness you can imagine. I've seen 1/2" steel checker plate, plenty of 3/8" aluminum checker, all the way to thinner than 1/8"...
    For a floor I'd use as thin as 16 gauge steel checker and add some supports underneath. Then again, for the price you might as well get the replacement floor sections from LMC or JC Whitney and save yourself some aggravation.
    My 2 cents...
    Rene
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I'd bet it would look good..... I plan on using a little diamond plate for cosmetic reasons if I ever get around to interior work.
  5. BlitzK5
    Jul 29, 2005
    288
    I am currently in the process of installing it know. I will post pics when im done. The only draw back is the cost. It cost me $400 canadian for 2 3x6 sheets:(
  6. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    diamond plate floor
    i have replaced my entire floor with 1/8" diamond plate steel bolted to 1/4" 2x2 subframe it is as strong as can be but added over 500 pounds to the weight of the vehicle. 1/8" diamond plate steel weighs in at a little over 6 pounds per square foot, so dont use it if trying to keep the vehicle light.
  7. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I used steel diamond plate of the 1/8" variety (1/8" plate not including the height of the treads, some call it 3/16" depending on the place :dunno: ), its not nearly strong enough by itself, I made a 1.5" by 3/16" subframe with a 2x3" tailpan and bolted it all together, welded the body to the sheet and when and if I get to that point attaching the cage to the frame and body.
    http://coloradok5.com/forums/showthread.php?t=102779
  8. BlitzK5
    Jul 29, 2005
    288
    ok Here it is, im done. I went with 2 3x6 sheets of 3/16th diamond plating.
  9. DaPlumber
    DaPlumber 1/2 ton status
    Apr 4, 2003
    212
    Holland Oh.
    WOW :bow: :bow: Thats so sweet :eek1: :eek1:
  10. NYDIESELDAVE
    NYDIESELDAVE 1/2 ton status
    Aug 6, 2005
    166
    Penfield, NY
    That looks killer! Any plans for diamond plate int side panels?
  11. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Yeah, I want some of those too. Guess I'll have to break down and make 'em myself.....
  12. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,496
    1,206
    So Cal.
    with that thick of aluminum do you think you added weight or was it about the same or maybe more weight then stock floor?
  13. BlitzK5
    Jul 29, 2005
    288
    Im preatty sure I added weight but im not sure how much. I most likely doubled it since I built a frame with angle iron for underneath.
  14. BlitzK5
    Jul 29, 2005
    288
    I would like to but that wont be for a long time. I still have to do all my gears first. LOL
