Aluminum Lift blocks?
Discussion in 'The Garage' started by y5mgisi, May 31, 2005.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    3"rs Are they a yay or nay? For the rear of a suburban? they are not solid blocks they are more like a normal cast iron block but theyre aluminum. Should i use them or not?
  2. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    I personally wouldn't trust 'em.
  3. gmcjimmy88
    gmcjimmy88 1/2 ton status
    Feb 10, 2005
    559
    Fayetteville North Carolina
    I would get the cast iron ones at least. I broke two sets and the third I busted the pin out of it. Got cast blocks and never had any more troubles.
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Most of the aluminum blocks I have seen are for lowering, not lifting. I wouldn't use them.
  5. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    alum for rims but not for lift . just my opinon.:D
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Go with 3" steel blocks, they will be fine.
  7. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    sounds like a bad idea then. Would it be ok to drive on it for a couple weeks with easy driving ya think? or are they gonna crack as soon as i hit a pot hole?
  8. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    all depends on the grade/type of Aluminum... some of them are PLENTY strong for this application and many others are not. If you know what its made of (specifically) it'd be easier to make an informed decision. If "its aluminum" is all you can find out about it, I'd recommend using steel ones instead...
    j
  9. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Agreed, blocks made out of T606 grade would probably be the most desirable, for aluminum blocks anyway. As far as just using them for a few weeks....regardless of their grade I don't see a problem with that. Especially with a 3" block. Just keep your eye on them for cracking but most importantly, don't let a couple of weeks turn into a couple of months...then a couple of years.... If you plan on using them for a couple of weeks to get by then do it....but only for a couple of weeks. Unless they are a top quality, premium aluminum like T606.
