Aluminum pinion angle shims???
Discussion in 'The Garage' started by mplogic, Jun 18, 2002.
  1. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    Just got some 2.5 degree Rancho shims for my 89 Blazer 3/4 ton conversion with a 4" lift (3" Tuff Country springs, 2" Hill shackles). I was a bit surprised to see they were made out of aluminum. Feels a bit strange to be torquing down some soft metal between spring steel and the heavy front end housing. Anyone ever had any problems with these cracking or coming out? Also, anyone know if steel ones are available?
  2. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Aluminum shims are junk. They corrode and the centering hole wollows out. I made some custom zero rates 1" thick with a 3.5 deg angle milled into them (out of steel). These are bolted to the spring pack. You could do the same if you bought a set of zero rates and took them to a machine shop. Be sure to get the hole spot faced on the bottom so the centering bolt will sit squarely.
  3. I did what Thebigdaddyof2 mentioned. Here's a pic. A buddy works in a machine shop and made my center bolted blocks for free (well I bought him lunch). I started with blocks that were about 1 3/4" tall and had a 3 degree angle machined on them. Worked very well. [​IMG]
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Scotts (4X4HIGH) cracked into pieces. He then made some from heavy gauge steel. I bet he'll post later on tonight. /forums/images/icons/tongue.gif
  5. mplogic
    May 7, 2002
    263
    Phoenix, AZ
    hmm. Thanks guys, that's what I was afraid of. I already put them in, but I'll probably have a shop fab me up some steel ones shortly. I'm using 3" tuff country springs in the front and don't like blocks in general but I would like to do something to bring that centering bolt back into the perch more. What's involved in removing a centering bolt and replacing it with a slightly longer one?
  6. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    take off nut pull out old put in new with new shim put on some locktight or something to keep nut from backing off and torque it back down.
  7. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    Sorry to tell you but almost every other trip I had to replace them. They would just break in half. I fabed some out of steel and they work great. A machine shop could do this for you. /forums/images/icons/grin.gif
  8. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    are steel shims available at the local/nolocal parts store??
    anyone have a source??
    ARQ.
  9. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Here is a site of a guy that makes them. I bought a set of 8 degree shims from him. He does OK work for the price. They were 8 degree, but one was about 1/64"-1/32" of an inch thicker than the other. Shouldn't make much differnce, but I am anal.
    I think he uses a band saw to cut these out. The cuts are straight, but if he doesn't center the block, whala, the two half are not the same.
