aluminum rad and taurus fan with a 350
Discussion in 'The Garage' started by muddyblzr, Oct 2, 2006.
  1. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    im being given a 17X28'' aluminum two core radiator. i was thinking about using a taurus fan on this but will it be enough to cool it? im planning on getting a better thermostat and water pump
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    Those taurus two speed fans pull an incredible amount of air... They will cool a mild big block, forget a small block!
    Aluminum rads are pretty efficient for getting rid of heat too, so it, combined with the taurus fan should keep your small block cool on even the hottest Texas day!
  3. muddyblzr
    Nov 2, 2004
    623
    alright i kinda thought so. ive been reading up about the fan and the numbers ive seen bein thrown aroudn are about 4000 cfm. i figure hte aluminum radiator, fan, better aluminum water pump and thermostat i should be just fine
  4. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Well, I'm hoping to cool my 500 caddy with one...prolly not gonna work but I guess only time will tell. :o
  5. Russell
    Jun 23, 2000
    7,923
    333
    Lets put it this way, I've got a 3.8 V6 electric fan on my 80 K25 with a TPI 355, and a secondary fan from a 4 cylinder Nova. I've never once had the secondary fan turn on, even with the truck just sitting there and idling for hours on end while I fiddle with the chip...
  6. muddyblzr
    Nov 2, 2004
    623
    im not so much worried about the fan its more is the radiator big enough to cool it
    its 17x28
  7. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    IIRC Marv Sprenger had a big block buggy (with an open engine compartment) that he cooled with a 19x26 and it worked just fine.
    Anybody know the equations for horsepower vs. heat?
  8. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    True dat...!
    Mikey,
    There's way too many variables to put your arms around this I'd think... :thinking: aluminum heads, manifold, efficiency changes based on CR and cam... :crazy:
    But I know you can't go wrong going aluminum over Copper-Brass....
    Marv
  9. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I know, I just thought someone made a VERY general equation at one point in time. I should go back to those SAE manuals. :doah:
    Like I said, I'm pretty friggin worried about this Caddy motor, 500 cubes and a 19x28...we'll see.
  10. muddyblzr
    Nov 2, 2004
    623
    marv what fan did u use? taurus? got any pics of the mounting
  11. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Yes... 2 speed Taurus.
    I don't think I have any pics of it tho.... :(
    Marv
  12. muddyblzr
    Nov 2, 2004
    623
    ahh alright im not really sure how to mount it the fan shroud is almost as big as the radiator
  13. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    This is a project I want to tackle soon, what is the general consensus, the Windstar fans or Taurus?
  14. muddyblzr
    Nov 2, 2004
    623
    depends on what you want. i cant fit the dual windstars so im going with the single taurus
  15. Russell
    Jun 23, 2000
    7,923
    333
    I'd assume it'd be best to cover as much of the rad as you can, so you can be sure you are cooling a wider area of the rad instead of just a single concentrated spot where the fan sits.
    I personally plan to go with the single dual speed Taurus fan, for both my 96 and my 80.
  16. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    So for comparison sake, what measurements match the Taurus fan? I'm sure I can search the answer for the Windstar.
  17. wetbackZO
    wetbackZO 1/2 ton status
    Jan 30, 2006
    113
    Las Cruces, NM
    what's the price on a taurus fan??
  18. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Got mine for $35.
  19. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Mine was like $25 or $30 IIRC.
  20. Russell
    Jun 23, 2000
    7,923
    333
    Can't remember off the top of my head, but I believe there is a 1 - 2" gap at the bottom, but just about perfect side to side :)
    Russ
