Aluminum Wheel restoration questions??
Discussion in 'The Garage' started by tiger9297, Jan 7, 2005.
  1. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    Have a '90 K5 w/ stock aluminum wheels. In my opinion these are great looking wheels but they do have 15 years of wear. I have heard there are places that will restore aluminum wheels and they will look brand new. I would do it myself but there is a plastic-like film over the wheel. I guess this was for protection but I think this is actually what looks worn. The actual wheel itself may be fine. Don't know what to do with this film or if I remove it how the wheel would be protected in future use. Any ideas??
  2. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    You can chemically strip that coating off and Eastwood sells a good polishing kit for Al wheels. I have done it before, takes a little time but comes out great if you are careful and take your time doing it.
  3. tiger9297
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    Where can I get one of those Eastwood kits?
  4. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    If you really want to make them look new I would sand them down first with 220 grit and then again with 320 grit. If you don't have a very good buffer then send them off for a pro. buffing polish. They will come back better than new.
  5. tiger9297
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    Where do I send them? Do you have any suggestions?
  6. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Yes you can strip them yourself, its just basically a clear coat paint. Body shops will reseal them for you, I would deffinetly get them resealed as this will give them the shiny appearance and cleanup will be much easier than bare alluminum.
  7. tiger9297
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    what should i use to strip them? MEK?? I can spray the clear coat on myself. I have never done this and I definitely don't want to screw up a good set of wheels? Where can I get one of those Eastwood polishing kits?
  8. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
  9. bigblock44k5
    Jun 8, 2003
    396
    Hurlburt Field, FL
    You can strip them with any paint stripper. Just only let it sit on there long enough to soften the clearcoat so it doesnt hurt the aluminum.
  10. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    I had a powdercoating company and I used to do aluminum wheels all the time
    1)strip using plastic media... doesnt dig in the aluminum... you can use aviation stripper but that is messy and time consuming
    2) repolish with a machine polisher... to a mirror finish.... or if you want the satin look just clean them up
    3) recoat with clear powdercoat (of course theres a pre wash etc)
    should run about 100-150...
    some of the polishing guys in L.A. get big bucks ripping people off... the process is really simple
  11. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    i don't know who could sand them down for you, you would have to call around and find out who can do it. I would bet that somone local that buffs wheels could also sand them down. As far as the clear coat....sanding them will remove any clearcoat. If you really want them to look better than new and take out shallow scratches then you want to completely sand them down with 220, then 320 grit, and finally a really good buffing job.
    That is how all the shiny over the road Peterbuilt trucks stay looking so good. I have done tanks and 22.5" alcoas with our semis and they always look great afterwords. In fact, non polished alcoas come out of the box with a brushed/sanded finish ready to be buffed.
    But hey thats just the blingmaster's 2 cents. :D
  12. sickquad
    Jul 23, 2003
    785
    Ma
    If you are taking about polishing them you need to go a lot further than 320. For a good polish I always go 220 320 400 600 800 1000 grit, then polish in two steps.
  13. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    While the stock wheels are pretty nice looking, I think that there is one more thing to consider. Compared to the cost of having them redone, you could probably buy a brand new set of awesome looking aftermarket wheels for the same (or maybe even less) money. :yikes:
  14. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    :screwy: A good buffer will easily remove the fine scratches 320 leaves behind and leave a mirror smooth finish, or at least that has been my experience when doing fuel tanks and Alcoas.
  15. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I have good luck cleaning up old aluminum wheels with stuff called Naval Jelly. Meant for cleaning and polishing aluminum. Mother's alumkinum polish is good stuff too.
  16. CARL
    CARL Registered Member
    Apr 3, 2002
    14
    Refinishing Plastic Coated Alum Wheels
    I'm in the same boat.....checked out sending wheels out ....$100 or more to strip and refinish.
    Medial blasting is great to polish the spun aluminim.... cost becomes an issue, and plastic coat has to come off w/o scratching the milled look.
    Por -15 has a Wheel Restoration kit to refinish the wheels with a 2 part clear and adhesion promoter to stick to polished aluminum. Have used there products and been thrilled. Have been dealing with Pat Dolla at Por-Can for years....has not let me down yet. there web page is www PORCAN. com
    had thought of scuffing the wheels w/ 400 grit water paper and priming with vari prime to etch to the aluminum. Paint with silver base coat (bright metalic) to match the silver stripe on truck side, and clear coat wheels with Por-15 2 part clear for aluminum.
    Por -15 also has a color kit for polished chrome & aluminum. Have seen the system...looks great! Wild colors that look like colored mirrors!.. Am planning to polish the stainless steel trim on silverado blazer to finish up the street rod look on my 90 silverado for a more retro look.
    Remember polished metals and refinishing are an oxi-moron. Any finish needs to bite to the surace to stick. Open the above web page and make an informed choice.:grin:
    good luck
    carl:cool1:
  17. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Hey, my aluminum wheels arent coated, and therefore oxidize over too quick for as much work as it is to polish them. Do y'all know of any way to protect them? Ive heard of applying a coat of wax to seal them, does this work? Seems to me that the wax would just melt from brake heat and make a nice mess. Im not wanting to drop the $$ to get em coated, just wanting somethin to keep em bling for a little longer than they do now. When I polish em, they look killer (course the primer door kills the look lol), but they just oxidize too dang quick. Especially the rears since I run side exit exhaust, but the front do it almost as fast. Thanks guys.
  18. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I guess a clearcoat.
    I wonder if my welds have a clear coat. :thinking:
  19. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    if you take mothers polish (what I use) and rub em and it turns black, they aint coated, if it dont turn black, they are coated.
    I might try the wax, I aint got the $$ for clearcoating, maybe after I get it painted, and dethrone RJF as bling bling king :)
  20. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Look at these wheels on my Jimmy.
    They were the ugliest aluminum wheels I had ever seen. I purchased some wheel cleaner that acid etches them stripped them down cleaned them to bare aluminum then shot clear coat on them. It took about 20 hours total time to do this but It was worth the effort. I paid $75 fo the set of Hurricane wheels from a friend. He was very jealouse when he had seen what I had done with them.
    Like I said, it will be worth the effort. Good Luck!:) [​IMG]
