always pull off the diff cover to be sure!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Jun 29, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i just removed diff cover from 12 bolt under an 82 pickup out here and it turns out to be a 73 axle with clutch type posi and 3.07 ratio, i assumed it was 2.76 peg like most other 80-82 era 12 bolts with three speed auto usually are, also figured if it was gonna be posi that it would be gov lok, but well its not /forums/images/graemlins/laugh.gif SPID lable on truck said no G80 posi, so definitely a swapped axle for sure.
    you just never know from the outside
    pull your covers
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    didnt 82's come with 10 bolts front and rear?
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    looks like it was swapped...
  4. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    what im sayin is, in 82 they came with rear 10 bolts, so if he was pulling the cover off of a 12bolt, then obviously it was swapped right?
  5. Confedneck
    Nov 1, 2002
    5,236
    what about 3/4 tons? i donno, doh my bad...
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think the 12 bolt rear can be found all the way up til 82 depending on what GM had laying around.
  7. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    so some 82's had 12's and some had 10's?
  8. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    My 81 Jimmy had a stock 12 bolt rear...prolly because of the 4 speed. Who know's, it has a 14 now and that's what really matters.
    Rene
  9. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    yep, i've seen a few 81 and 82 that still had factory 12b rears....shocked me also.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    DITTO!!
    IMO, a 10 bolt is stronger or equal to a 12 bolt anyway. 12 bolt has bigger axles, but the pinion and bearings are smaller. If you break the pinion bearing, who cares what size the shafts are?
  11. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    When I first went to look at the truck I was impressed that it had a 12 bolt...then when i went to test drive the truck the 12 ate a grenade and blew the spiders through the cover backing out of the spot the truck was in./forums/images/graemlins/eek.gif
    The car lot spent $750 to get the 2.76 geared open 12 bolt rebuilt before I got the truck...just so I could yank it for a 14 bolt a couple of weeks later.
    My confidence in half ton rears pretty well evaporated that day.
    Rene
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Mine didn't when my 10 bolt grenaded from a loose pinion nut.
    Only when the 12 bolt pinion bearing exploded and the pumpkin spun on the housing and the pinion was pushed through the cast iron case was my confidence in 1/2 ton rears history.
  13. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    /forums/images/graemlins/rotfl.gif/forums/images/graemlins/grin.gif If it's gonna die it might as well be spectacular! /forums/images/graemlins/thumb.gif
    Rene
  14. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    Rene
    lol !
    ive seen my share of truck 12 bolts come apart also
    keep in mind that truck 12 bolt have smaller pinion bearing than other axles such as the dana 44 and 8.5" and such, technically stronger than 12 bolt truck just right there. ralso gears are prone to shattering if you impact load them such as doing something like spinning out on gravel headed for clean pavement, or putting car in gear at a little higher than idle, all i see is pinion nut come loose and there goes the pinion setup..
    i know of several 82 with 12 bolt axle, 82 was last year to see a 12 bolt, this is one of those things like the 77-79 K10 front axles, some ppl say 10 bolt and some say 12 bolt, personally all i ever see under 79 and older are dana44,. so.... either model fits under just fine just like 12 or 10 rear, except U joint
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think I fixed that problem today FOREVER!!
  16. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    I saw that...congrats dude!/forums/images/graemlins/thumb.gif
    Rene
  17. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    have 14 bolt now ? FF ? whats in the axle ? and what ratio wa sin the 1/2 ton axle ?
    pics ?
  18. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    WHY A DIESEL? - Gasoline engines are a thermodynamic abortion. Ever wondered how the hell they manage to work at all? I'd have a diesel weedeater if they made one. /forums/images/graemlins/grin.gif
    LMAO!!!!!!!
