Am I doing something wrong, 14bolt ???
Discussion in 'The Garage' started by mudhound72, May 12, 2005.
  1. mudhound72
    mudhound72 1/2 ton status
    Feb 15, 2005
    474
    Oshkosh, WI
    Ok I know this is a stupid ?? but something just dont add up. I am checking the gear raito in my 73 burb did not have the chance to pull the diff cover but I made a mark on the drive shaft and on the tire and spun the shaft, I got 1 3/4 turn per a tire rotation, I did not think 1.75 raito was right so I spun the tire got about the same, I then tryed to spin the tire 10 times and got about 15 3/4 turns.
    Some one try to help me make heads or tails WTF is going on here this is driveing me nuts :( :( :( :( :( :( :( :( :( :( :( :( :( :( :( :( :( :(
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Did you have one wheel on the ground? IIRC you must have one wheel on the ground then rotate the wheel that is off the ground one revolution and see how many times the driveline spins. I would bet you have 3.73's.
  3. Boondocks
    Boondocks 1/2 ton status
    May 10, 2005
    129
    Massachusetts
    I agree with 4x4High.
    Do you have a the lift-gate right lock tang?
  4. mudhound72
    Feb 15, 2005
    474
    Oshkosh, WI
    Yes, I did have one or the other tire blocked, Factory it came with a 454 now it has a 500 cdy, not sure if it is oem or not allot of stuff was changed around.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    WTF? :screwy:
  6. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    Sounds more like 3.21's than 3.73's. 454 'burb would be 2Wd right?
    Best bet is to pull the cover and get the numbers off the ring gear edge.
    Rene
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    with 1 tire off the ground, spin the tire two times to get the ratio. if you did it 1 time, you need to double the rotations of the driveshaft because you are turning the spider gears also.
    i like to spin it twice to get a more accurate counting than doubling it.
  8. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    yep big 83 is right, you spin it twice. :)
  9. mudhound72
    Feb 15, 2005
    474
    Oshkosh, WI
    Ok I did not want to, but I am going to pop off the rear diff cover to find out for sure. I am going to run this for a few months till I install something bigger and better. I am rilly hopeing that it is 3.73 just so it can pull alittle bit better, so I dont need to take out a lone every time I want to use it.
  10. mudhound72
    Feb 15, 2005
    474
    Oshkosh, WI
  11. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    The 3.21 ratio was a 2WD only thing...so it's possible. Prolly pull real good with some 24" tires. :)
    Rene
  12. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
  13. Boondocks
    May 10, 2005
    129
    Massachusetts
    From the preceding message
    I have parts comming out of my ears, ask me if you need the odd ball 69-72 parts
  14. mudhound72
    Feb 15, 2005
    474
    Oshkosh, WI
    Ok I pulled the cover off and the mystery is solved it has 3.73 just what I was looking for :D
