Am I dumb? 10 bolt calipers on a 44
Discussion in 'The Garage' started by Sample, Sep 17, 2003.
  1. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    Just swapped the 10 bolt out for a 6 lug 44. Everything has went great except for one problem. I cannot get the 10 bolt calipers to go on the 44. They fit fine with out the pads in them, but when you put the pads on they don't. No it isn't because I didn't push the piston in, the brakes fit fine in that respect. I can only get one caliper bolt hole to line up. These are the used pads from the 10 bolt. /forums/images/graemlins/thinking.gif
  2. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    look for a little bump on the bottem of the calper you may need to grind it off that is the only thing i think of
  3. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    I will have to look for the bump. The funny thing is, the calipers fit fine without the pads in.
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Going from 6 to 8 lug????
  5. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    Nope, 6 lug 10b and 6 lug 44.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Take the backing plates off the old axle and swap them over if it won't work.
  7. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I second that backing plate idea /forums/images/graemlins/thumb.gif
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ok, one other thing no one has mentioned, did you compress the piston back into the caliper? Maybe it is out too far?
  9. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
  10. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    I am takin' the grind it 'til it fits approach.
  11. the cork
    the cork 1/2 ton status
    Apr 20, 2003
    128
    mid west,
    you also have to push those bushings back that the bolts go through, as the pads wear they slide,
  12. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    What are you talking about? I can't even get to the point of putting the bushings/screws in.
    I have been grinding stuff off and cannot get them to fit. I can't swap backing plates because the driver's side rotor is welded on due to the inner wheel bearing being shot.
  13. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    That sucks....
  14. the cork
    Apr 20, 2003
    128
    mid west,
    look at the caliper were the bolts go through, theres a little sleve about 3/4 inches long that the caliper rides on, as the outer pad wears the caliper has to move to take up the slack, sounds like yours are frozen solid, i would
    remove them and put in a new bushing,and rubber piece,
    so the caliper can operate correctly, dont know how else to
    explain it, unless you have a bendix style, ive put 10
    bolt calipers on a dana 44 and only had to grind that bump off,
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Don't worry about brakes on that side at all then. When the wheel bearing welds itself to the spindle, you'll have instant hardcore brakes on that side.
    Just fix your brake line with vise grips and a hammer and you'll be ok. No need for brakes on that side if your wheel bearing is going to lock up soon.
  16. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    [/ QUOTE ]I already experienced the lock up, smart ass. The rotor is stuck on the axle that I just took off, not the one I just put on.
  17. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep, the bolt slider sleeves need ot be pushed back threw away from rotor side of both sides of the calipers, pulling them rest of the way through and greasing them and pushing them in from the outside side of the calipers and then putting the two slider bolts through would be a good way to do it
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Cut the damn rotor off and quit your bitching then.
  19. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    I am only going to say this once. [darn] you and your slack jawed mom.
  20. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    swapped the fronts on my 73 (D44) & 80 (10B) w/ no issues
