Am I over thinking this?
Discussion in 'The Garage' started by mrk5, Jun 29, 2004.
  1. mrk5
    Apr 20, 2004
    12,351
    1,051
    Northern Colorado
    For the longest time I thought I had 3.73 rearend gears. But I've since found out CUCV blazers came with 3.08s. I started checking things out, used the calculator on Randy's and what matches up perfect with my RPMs at various speeds is 3.42s in the rearend. This is true even with the tranny in 2nd. The only thing I haven't done is pull the cover and count teeth.
    Here's what's occupying my mind. Could it be that my blazer actually came with 3.42s.
    Or is my tranny slipping that bad? The only other thing I've noticed is that when the tranny is good and warm, I have to give the motor some throttle to get it moving in reverse. When you first pop it in gear, it is just like it's still in neutral. I've been keeping an eye on the fluid and it is nice and red. I know that reverse and direct drive share clutch packs.
    Basically I can either drop $1000 on the tranny or new gears on the axles. What are the opinions.
  2. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Well...To put all doubts aside pull the cover and count the teeth! Then come back and go from there. You don't want to make too many assumptions if you aren't sure what the problem is to begin with /forums/images/graemlins/thumb.gif
  3. mrk5
    Apr 20, 2004
    12,351
    1,051
    Northern Colorado
    Yeah I know. But I work fulltime and then 3hrs of class /forums/images/graemlins/frown.gif. With this being 4th of July weekend, I'm looking at two weeks before I'll have time to do it.
    The wondering is just about killing me /forums/images/graemlins/screwy.gif, so I just had to get it off my chest.
    I'm mostly curious if the 3.08s in M1009 is set in stone or if there were variations.
  4. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Have someone drive it real slow and count the driveshaft rotation and number of tire rotations. Then divide # of tire rotations into # of driveshaft rotations.
  5. 82diesel
    82diesel 1/2 ton status
    Jul 2, 2003
    316
    Stockton, CA
    Or you can jack up the passenger rear tire and rotate it by hand one full turn while counting the turns of the driveshaft.
    Mark the drive shaft with white out or something similar to get exact.
    Then times that by 2.
    1 1/2 rotation is 3.08
    1 3/4 rotation is 3.42
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Assembly line waited for nothing. If they were a day or two away from delivery and all they had was 3.42's , it got 3.42's . That one of the reasons we see some weird non-COPO combos out there.
    Wait until you have 1 hour free and drain the fluid , read the numbers on the side of ring gear , and seal her back up /forums/images/graemlins/k5.gif
  7. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Unless it has a spool or welded spiders you have to rotate the tire 2 times.
    A spooled diff takes one rotation of the tire and has to have both wheels off the ground.
    If the wheel can be rotated with only one wheel in the air then you spin it 2 times.
    Make reference marks on the wheel and yoke, rotate the tire twice and note the revolutions on the yoke.
    2 people kinda help, 3 and a bit=3:08, almost 3 and a half=3:42, 3 and almost 3/4= 3:73, 4 and a bit is 4:09/4:10 and so on.
    Chock the front wheels, raise a wheel and give it a spin.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would say it has 3.08s. The reason you think that it has 3.42s per the chart is that it has a TH 400 which has a noon-lockup torque converter.
    1009s have 3.08s.
  9. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    There should be an axle code on the drivers side axle tube--I have found only one in the spot the factory book tells you to look for it--many I looked for were either not stamped at all,or somewhere I couldnt see it,or it rusted off--I think its quicker and more reliable to pull the cover.You probably need new gear oil anyway!. /forums/images/graemlins/crazy.gif
  10. mrk5
    Apr 20, 2004
    12,351
    1,051
    Northern Colorado
    You're right on the gear oil. I've only ever checked the level.
    I have tried rolling the truck and counting rotations and came up with 3.
    I haven't done the jacking one side up yet.
    I appreciate all the comments. I'm just going to have to wait until I can pull the cover I guess. Course I'm tempted to not even worry about and just put 4.10s in the D44 and 12b I have sitting around and be done with it. I think I would really be smiling with 4.10s.
    But at least I can feel better getting all these musings off my chest. /forums/images/graemlins/smirk.gif
