Am I the only one?
Discussion in 'The Garage' started by scoutillac, Mar 28, 2004.
  1. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    Am I the only one who lifted his rig and didn't drop his bump stops? Do we really need to? The burb front fenders are going under the plasma cutter this week. How far back should I cut. Show pics please. /forums/images/graemlins/hack.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I haven't but I only run 4" lift or so. I might after I cut my fenders some more to limit up travel though. Right now the tires stop against the fenders not the bumpstops.
    Harley
  3. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I haven't, but I think the tires will hit fender before anythign bad happens
    I imagine you can break springs without them on some applications though
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    The reason for bumpstops is so that your axle articulation stops before you crush a shock or shear it off the frame.
    To see if/how much you need to drop them, do the following:
    1) With your truck parked, measure the distance from where the bumpstop would make contact with the axle.
    2) Now measure the amount of shock rod you have sticking out of the body (basically, how much more travel the shock has).
    3) Subtract value #2 from value #1 and that will tell you how big of a spacer you need to put in there. (You may want to add an inch to this value, just to take into account the rubber bumpstop compressing a bit).
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Come to think of it I don't even have bump stops on mine. /forums/images/graemlins/dunno.gif /forums/images/graemlins/thinking.gif [walking out to truck] Yep, no bump stops /forums/images/graemlins/grin.gif
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Yeah i haven't dropped mine with the 4" lift, and i am still always sittin on them bouncin when i get flexed out a bunch. /forums/images/graemlins/thinking.gifReminds me of my lowrider days. /forums/images/graemlins/whistling.gif
  7. mr_fujisawa
    mr_fujisawa 1/2 ton status
    Sep 1, 2003
    288
    SF CA
    i haven't dropped my bumpstops either. . .
    didn't really know it was necessary. . .
    do you need to for a 4" lift or is it mostly for the larger lifts?
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have them up front, I think my shocks are setup so I could remove them and the axle hit the frame before they bottomed out though. /forums/images/graemlins/smile.gif
    There is no reason to drop your bump stops anyway unless you're trying to make your springs last forever. Me personally, I want the flex, so I don't care if my springs wear out eventually.
  9. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I havent dropped any of them.
    I have 8" springs on the Truck Blazer, and today it was flexing pretty hard when I was trying to crawl up a bank to get up to pull out a stuck Ford Ranger. I definitely had some tire/fender rubbage. My fenders arent trimmed enough for the 40's.
  10. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    I wonder this myself, I would do it just to make sure my springs don't go past being flat when flexed out, my shocks don't seem to be a problem and the rear I figure wouldn't go any further than the overload leaf. I might put a little block in the front, but the rear is no problem. I'm running 4" lift and no sway bar.
  11. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    What's a sway bar? I haven't seen mine. Oh wait yeah I have it's hanging on the wal in the garage. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
