american racing rims
Discussion in 'The Garage' started by 88-3/4t-bad boy, Sep 10, 2006.
  1. 88-3/4t-bad boy
    88-3/4t-bad boy 1/2 ton status
    Nov 27, 2005
    150
    Texas
    ok everybody. what i thought was a set of american racing 16x8 rims were not. they are 16x7's took them off today and read the back. so i need some new wheels. im am thinkin of some american racing baja 16x10 rims. it says they have a 4.5" backspacing. is that good or bad? also a 8 lug pattern for the suburbans is 8-6.5 right? they are on sale and ive always liked these rims. also will the hub centers from my old rims fit on the new. and what size lug nuts do i need? :confused:
  2. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    Yes on the lug pattern and that BS will push the wheel out a little for better turning radius befor hiting the springs.
  3. 88-3/4t-bad boy
    Nov 27, 2005
    150
    Texas
    so the bs is a good thing? if i want to turn.
  4. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    i thought the more backspacing a wheel had the further in it was
  5. 88-3/4t-bad boy
    Nov 27, 2005
    150
    Texas
    ok, so which is it. or is 4.5 ok for my sub.
  6. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    K5floyd - yes
    .....just think H1 hummer rim with 7.5" backspace on SRW front tucked WAY into the fenders
  7. k5floyd
    Feb 6, 2004
    313
    Friendswood, Tx
    isnt stock backspacing like 3.75in, so wouldnt that mean 4.5in backspacing put the wheel further in and not out like 6.2puller said
  8. k5floyd
    Feb 6, 2004
    313
    Friendswood, Tx
    bumping this back up because i want to make sure i understand the BS thing because im ordering new wheels
  9. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    on a 10in wide wheel. 4.5 is less than half, meaning you got 5.5 sticking out. I have 15x10 with 4.5 and no problem.
    btw, what size of tires are you running and lift? the wider the rim the more problem you might have with fender clearence
  10. k5floyd
    Feb 6, 2004
    313
    Friendswood, Tx
    EDIT: so if im running 35x12.50s on stock rims 3.5" BS on a 15x8 wheel should be good to push the tire out just a bit which is what i want
    sorry for the partial hyjack im trying to figure out the wheel thing too
  11. 88-3/4t-bad boy
    Nov 27, 2005
    150
    Texas
    well i actually am going to order 16.5's they are cheaper and i want to get some dick cepek fc 36x15.50 or 36x16.50. i have a six inch lift.
  12. 88-3/4t-bad boy
    Nov 27, 2005
    150
    Texas
    what size lugs and crap do i need though?
  13. k5floyd
    Feb 6, 2004
    313
    Friendswood, Tx
    so long as the 16.5" wheels have the same bolt pattern theyll mount fine you should be able to use the lug nuts you have now i beleive
  14. 88-3/4t-bad boy
    Nov 27, 2005
    150
    Texas
    oh. ok. thanks.
