American Thread sizes?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JORGE, Apr 18, 2002.
  1. JORGE
    JORGE 1/2 ton status
    Jan 10, 2001
    213
    VITORIA-GAZTEIZ(ALAVA)BASQUE COUNTRY,SPAIN
    Hello,
    I,m looking the way to install a Isppro temperature gauge in my 6.2, but i,ve a trouble.I would need to change the sender by a isspro sender too,and i don,t know what is the correct.
    The original sender on my 6.2 engine,has a 17mm diameter and a 1.5 wide ,but in the metric sizes doesn,t exists the M17X1.5,it pass from M16x1.5 to M18X1.5. Maybe this sender size corresponds to any American thread size,that i don,t know.
    If somebody could to help to me i would to thanks to him.
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    It's probably tapered pipe thread. I don't have a chart handy here to confirm that though. 17 mm seems like it would be awefully close to 3/8" pipe thread...
    rene
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    If you are plumbing into the block it is going to be pipe thread.Pipe thread and regular threads are different.
  4. JORGE
    Jan 10, 2001
    213
    Do you want to mean if i checking the hole size,in the block?
    No,im checking the sender size,But if its possible you have reason.If the sender has 17 mm,the hole can to be a 16 mm.
    I,dont know.
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The sender unit going into the block will use tapered pipe thread. Also known as NPT. From your size description I'd say it is 3/8 NPT...
    Rene
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Yes, 3/8 NPTF. Not to be confused with 3/8 BSPT (British Standard Pipe Thread). 3/8 NPT is 18 threads per inch, and BSPT is 19 threads per inch. The world is a confusing place.
  7. JORGE
    Jan 10, 2001
    213
    Yes,The Isspro sender is 3/8 Npt, I have found and article wich says that all the GM engines,since 1980 have 1/2 to 3/8 senders.Thanks for all.Your help has been very valuable.
