ammo can locks
Discussion in 'The Garage' started by creampuff90k5, Jun 20, 2002.
  1. creampuff90k5
    creampuff90k5 1/2 ton status
    Feb 15, 2002
    142
    New Jersey
    The last time I was at the pistol range, I picked up two huge 40mm ammo cans for storage in the blazer. Since I run topless at least half of the year, I would love to find some way to lock the lids. Not that I keep anything of tremendous value inside (tools, jumper cables, etc...), but I don't want mischievous teenagers rummaging through them either. Anybody have an idea that won't look totally ghetto??
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    got on of those on my blaze. when i installed it i put silicon around the mounting bolts, so it's air tight. sometimes when the temps are right, the thing creates a vacumm as the day cools and i can't get the darn thing open. gotta really pull and kick it to open it.
    anyhow, i don't think you'd like to carry a vacumm pump around. but i've seen some with pad locks on them, not to nice...
    ARQ.
  3. Dieselmh
    Dieselmh 1/2 ton status
    910
    Texas
    www.cheaperthandirt.com sells ammo can locks. I don't know if they have them for the 40 cal cans or not, though.
  4. creampuff90k5
    Feb 15, 2002
    142
    New Jersey
    Do you have a more specific URL for these locks? I've been searching on their site for the last ten minutes with no luck...
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Do you have the tall cans with cam over locks on both ends? The ones I have has slots on those so I welded hasps on both sides and can put a master lock on each. Also since mine aren't bolted down I use a cable to make sure they don't walk off. /forums/images/icons/laugh.gif
  6. creampuff90k5
    Feb 15, 2002
    142
    New Jersey
    Hmmm. That hasp idea between the slots sounds pretty good. The only pain in the ass will be using four locks, since I have two boxes.
    BTW, I mounted mine to the floor using one of those "hood pin" kits like you see on muscle cars. When I want to take them out for more bed space, I just pull the hairpin clip off (accesible only from inside the box) and lift 'em up over the pins. Works pretty well.
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Just weld gate hinges on one side and the hasp on the other side. That way you only have to use 1 lock and have a hinged lid.
  8. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Since you've already drilled holes in them and they're not water/ air tight anymore, then weld the hasp on one side and put a carige botl on the other side. Use a accorn nut on the inside so you won't cut your self. Or put 2 hasps on and olny unlock one side the other side will act as a hinge when you open it. /forums/images/icons/cool.gif
  9. Dieselmh
    910
    Texas
  10. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    i have 2 big ammo cans in the back of my rig for storage, they are lockable. Just added a u-bolt on each side... in those little slots... and then I run a pad lock through it after the lid clamps down. Works great for me. As far as 4 locks being a hassle... its no biggie, when I wheel I pop all 4 off b4 I hit the trail.. if I need in, I just pop 'em open and go. Pics on webshots show how I did it...
    J
