AMOCO TRANS SHOP IN ARVADA
Discussion in 'The Garage' started by chevystepside, Mar 21, 2004.
  1. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    i would like to let you guys know about the worst experence that i have had in a long time with a shop. my 700r4 trans went out last june on a trip to nebraska. welli was planning on rebuilding it myself. being that i have been a mechanic for over 15yrs. while we were towing the k5 with my 73 stepside form nebraska i had two rockers and two push rods fail. so under the circumstances i decided to just let amoco on Miller street in Arvada rebuild it and i will have a nationwide warranty. well the trans didnt last 5 months. they gave me the run around for 1 and half months. findly they warrantied the trans which took 2 fn months. so go to pick-up my k5 and the front windshield is busted. tom the owner basically said that they are not going to fix the window. so my advise to anyone that needs to have any kind of trans work done DO NOT USE THE AMMOCO TRANS SHOP IN ARVADA ON MILLER ST. /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
    Dam I'm blue too SON OF A ----- MOTHER ------
  2. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    I was under the impression you were never supposed to use AMOCO... EVER! /forums/images/graemlins/dunno.gif
    On the other hand, it sounds like his store should have a front windshield problem as well. /forums/images/graemlins/hack.gif
  3. chevystepside
    Sep 23, 2002
    147
    leadville colo
    that has crossed my mind also.
  4. stock93
    stock93 Registered Member
    Feb 18, 2004
    68
    Huntsville, AL
    I had a problem with them leaving the rear transmission mounts off when they put a clutch in my S10 blazer. They also wouldnt warranty the clutch when it went out after a month with about 500 miles on it. They also left my front bolts off on my transfer skid plate which caused me a lot of problems when going over a log. I had to drive 2 miles out backwards. Needless to say I wont be going back to them.
    John
  5. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    2 miles out backwards /forums/images/graemlins/eek.gif that would have been harsh!
  6. the cork
    the cork 1/2 ton status
    Apr 20, 2003
    128
    mid west,
    is that a typo error amoco, or is it a different company than aamco, because i had aamco build my turbo 350, that i
    beat the crap out of with a 454 and never had any problems,
  7. chevystepside
    Sep 23, 2002
    147
    leadville colo
    yes it was a typo. the owner said that he has know doubt that it happened while it was at their shop. but they are not going to pay for it. i will mf the mf'ers every chance i get.they will never get a referal from me ever. the worst kind of advertisment is bad advertisment. i hope that any one needing any trans work DO NOT USE THE AAMOCO ON MILLER ST IN ARVADA COLORADO.
  8. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Threaten lawsuit, they'll kick out $90 for glass juts not to be hassled
  9. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Yeah, call up Judge Judy or file in small claims court. They have an obligation to return the truck in the same condition you left it.
  10. chevystepside
    Sep 23, 2002
    147
    leadville colo
    we filed a police report and had the officer show up at the shop before i left with my k5. so i have started the ball rolling with the start of a lawsuit. also going to call BBB and let them know what is going on that this shop.
  11. clubba68
    Dec 6, 2002
    1,511
    You should park your truck right out front with a big sign saying they F*d you. Like when people put their lemon cars out in front of dealerships with signs on them. /forums/images/graemlins/thumb.gif
  12. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i had problems with aamaco here in virginia , they
    suck. tried to rip me off bad!!. i got my truck out of there
    and took it elsewhere. i wrote a long letter to the b.b.b
    and let them put this place on the bad review list. never
    did get my 56.00 back for the initial check , but i didnt
    lose the 1800.00 they were trying to f-me out of . they
    siad all these things were bad and broke , and all it
    was , was a problem with the tcc and the speedo sensor.
  13. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Thanks for the info. I would also stay away from Cottman transmission chain. Forked me $350 to change the tranny cooler lines on my 78 K10 with TH350. I handed them the lines I had just bought from Inline Tube (all pre-bent and ready to go), so all it was was labor. I was going to do it myself as I have done them before (1 hour in the driveway). I was on my way to work in a snowstorm and the old line let go. My friend flat towed it to Cottman as I needed the truck to plow when I got out of work. I figured even if it cost me $80 bucks in labor, it would have been worth it to not have to take time off of work. In the process they broke my KickDown cable (less than 6 months old) and said it was old and brittle ([darn] liars), they broke my oil line going to the oil pressure gauge (mechanical guage) when they were working topside trying to change the kickdown cable, they left one cooler line loose, and they left some gear wrenches and screwdrivers on the cowl.
    I have talked to others that have been to Cottmans in other cities with similar experiences. Just about everyone I talked to said they felt like they needed a jar of vaseline after walking out of one of their shops.
