Amount of Driveshaft slip
Discussion in 'The Garage' started by Hardcore, Sep 26, 2005.
  1. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    1990 K5. Front axle moved 1" forward, rear moved 1" back, 6" lift (6" BDS springs up front, 4" shackle flip and 2.5" BDS rear, D60/14 bolt. NP 241 with SYE clocked up flat :wink1:
    About to order driveshafts. Will a standard slip driveshaft from H.A.D. be enough or will I need the long travel one???? What are you guys running
  2. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
  3. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I got all my DL stuff from Tom Woods. I really liked his stuff and his tech service was great. Just give him a call 1-877-4x-shaft
    As for your question with those springs I do not think you will have enough flex to need the longer travel slip.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Jess should be able to fix you up the best. He can talk with you about how you wheel and can determine whether you need an extended slip.. More than likely you wont... But support a CK5 supporter and call Jess!
