Amp Mounting Location?
Discussion in 'Audio' started by schwank, Sep 29, 2002.
  1. schwank
    schwank Registered Member
    Dec 7, 2001
    28
    PDX, OR
    I have a 91 K5 Scottsdale... as part of Fall maintenance, she's getting a much revised stereo system. I have already installed front Blaupunkt 3.5" speakers and have a template cut to build my rear sub box. Got some great ideas and info out of these forums, and I'm ready to roll.
    The sub box with 12" Lanzar is rear drivers side behind and up over the wheel well, like tightwork's here
    (nice job, btw!)
    Anyway, the 400W Alpine amp will be mounted on a removable wood base directly atop the arch, as they are pretty close to the same size. Thing is, that's a long power lead run from the battery in the front pass. corner, to the driver's rear wheel arch. 18-20 ft maybe... Even with a larger guage power lead, is this too much really? I am running a set of 6.5" like the tight one above, but my passenger side box is smaller, as I am keeping the spare. The amp is only powering rear speakers, so for wiring simplicity this is clearly the best amp location for me... but at what cost?
    Just looking for ideas I may have missed... how are you guys handling amp location? Thanks for your hints...
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    How much room do you have under you pass side front seat ??? Might be a good location for your amp. I've also seen an amp mounted in the console befor.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have mine under the drivers seat /forums/images/icons/smile.gif
  4. schwank
    Dec 7, 2001
    28
    PDX, OR
    I am hesitant to put my amp under the seat... my Scottsdale has no carpet, just a rubber floor. I use it to drive to Mt Hood in the winter and other backcountry activities around the NW. Lots of wet stuff in there frequently, like snowboards, wet gear, and my hound... so frequently this area is rather wet... not the greatest environment for an amp.
    Other ideas?
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    do you still have the factory side pannels along the bed? if so put it behind one of them /forums/images/icons/smile.gif
  6. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    Under the seat might work if you build in on maybe 1" plastic standoffs....just keep it off the wetness of the floor. Side panels can work well too, depending on how hot the amp runs....you may need to create ventilation for them so they don't go into 'thermal protection' mode...
  7. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I took my seat out, unbolted it from the floor bracket, sandwiched some wood in between the seat and floor bracket, and mounted my amp to this (upside down). Ran the wiring along the inside of the floor bracket to the carpet, and it worked like a charm. I also have mounted an amp inside the rear panels like has been discussed. It never ran hot and stayed out of the way.
  8. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I put mine in the in the stock center console.
  9. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Mine are mounted in the side panels. My amp for the subs has two fans in it so made sure that it had plenty of ventilation cause that sucker gets pretty warm in the summer months. Then on im running another amp up in the front of the panel and it has hardly any ventilation and it hasnt gone into themal protection mode, yet. My amp in the front is a US Acoustics with no fans and the rear amp is an Audiobahn A1300HC with two fans. Let me know if you want any pics.
