An Aluminum driveline?
Discussion in 'The Garage' started by mountainexplorer, Nov 2, 2006.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Last night I bought an NV4500 5spd that came out of a '95 Chevy 3/4 ton 4x4 for 500 bucks. The guy gave me the rear driveline out of the truck too, and it was extremely light. It looks to be made out of aluminum. That struck me as odd. Are aluminum drivelines common place or is this kind of a rarity?
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    They're pretty common on later model Chevy stuff.
  3. goldwing2000
    goldwing2000 Guest
    Ford stuff, too.
  4. mountainexplorer
    Nov 14, 2001
    4,903
    I guess I'm living in the past. '95 is newer than anything I've ever had. Just seemed weird to pick up this fairly sizable driveline and have it weigh almost nothing.
  5. goldwing2000
    goldwing2000 Guest
    With sufficient diameter, thick-wall aluminum has fairly good torsional rigidity and also flexes well enough to resist bending. It's good enough for a DD but I wouldn't use one on a trail rig.
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    they were avaliable on a number of years of newer trucks- as early as 91 I have seen with the aluminum ones. I recall only seeing them on 2x4's or something...
  7. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    94 gmc 4x4 rear shaft is alum.
  8. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    They've been using those in racing for a long time haven't they?
  9. 1977k5
    May 26, 2003
    9,995
    133
    Yep, driveline weight means a lot in racing. Chevy is probably using the aluminum driveshaft to help their MPG ratings (aluminum is more $$ than steel).
  10. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    Our 05 GMC Crew cab with a duramax has one and it is huge. looks to be 6' in diameter
  11. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    6 FEET??:eek1:
    :haha:
    all of the newer body styled S10's have them, im pretty sure.
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I run one in my Mustang to save weight. Alumnium DLs are very common in drag racing. Most Newer vehicles run them to save weight= better fuel MPG
  13. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    this is in a GMC 2500. Its about 6" in diameter. 1500's, vans, and fullsize suv's have them also. Dually's still run steel shafts. sorry for the pic. best I could do lying on my back on the lot.
  14. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    makes that yoke look tiny
