An Obscure Exhaust Question...
Discussion in 'The Garage' started by mikey_d05, Aug 25, 2005.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Alright, fall is here and the winter modifying will soon begin. I'm gonna taper/narrow the rear of the pumpkin as soon as I get a chance. I'm also going to rework the exhaust since my crossover pipe is a temporary hack job and the rest of it is falling apart. I'm going to run either a single or dual exit (haven't decided yet) coming out of the body at the location circled below. The pipe(s) will have to go between the inner and outer fender in the back, which I can cut to make fit...but I don't know how to mount it when it gets up into the body.
    I can't leave it loose because it'll vibrate and hit the body, and I can't use a traditional hanger because it won't really be hanging...I was thinking about solid mounting the tip with a flange like this one , but I'd probably break the welds on the rest of the system by doing that. Solid mounting the whole works and using braided flex hoses off the manifolds is starting to look like my best option. Just wondering if anybody has a better idea other than cutting a humongous hole in the body....if ya do, I'd really appreciate the help.
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    to make things easy, i would have them come out right infront of the rear tires at a swept back angle. If you can fit converters and mufflers (if you need them) that would look sweet to have it come out there. you wouldnt have really any clearance issues. just draw a line from your back tire to the rear bottom corner of your door. it would fit perfect and be a lot less work.
  3. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    God, any closer to where you sit and you may as well route it through the dash and into your lap...:eek1:
    I'd seriously re-consider your options.
    Rene
  4. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Ok, I've realized this is a flat out dumb idea...it won't be going there but I'd like to keep the tip up high...like higher than the floorboard...anybody have any good ideas?
    EDIT: I don't know what I was smoking, please let this thread die and may god have mercy on my soul.
  5. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    seems to me the hard part would be getting the exhaust up there. would you go over the frame, under the frame or through the frame?
    ryan
  6. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    This is how i ran mine...
    Soory the pic is a bit blurry, but it shows you just the same.
    Once it's outboard the frame you can get it right under the floor which is pretty high up compared to normal routing...
    I have yet to hit, maul or maim my tailpipe with it there.
    Rene
  7. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Thanks Rene, I can always count on you to make a helpful suggestion when I think up something totally off the wall. :D
  8. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Just didn't want to see you die from exhaust fumes while wheeling! :doah:
    Note that my tailpipe goes through the area the stock shocks used to go, in case yours still do.
    Rene
  9. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Right now there aren't any shocks in the back but I'm gonna build an inboard style setup before the exhaust gets done so I don't see it being a problem. Once again, thanks for your help, sometimes I just need someone to tell me it's a bad idea.
  10. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    We all need that now and then...myself included! :crazy:
    Rene
  11. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    You got me thinking about running it into the cab, well into the cargo area you would have to build a double wall type guard to keep it from burning stuff but it would get up pretty high then just exit out the opposite side that the fuel filler is on. Even though I suggest this I think it is to much work for too little effect
