And another shackle flip question
Discussion in 'OffRoad Design' started by achim1000, May 5, 2004.
  1. achim1000
    achim1000 Registered Member
    Jan 14, 2003
    9
    Hamburg, Germany
    I have installed the 4" shackle flip on my ´92 Chevy C1500. Everything went fine, but I have one question:
    I didn´t loosen the U-bolts that hold the axle to the springs, so I´m wondering if there will be a lot of stress on the drive shaft.
    What do you think?
  2. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    There's no need to loosen the u-bolts on the axle. There's a center pin located on the spring pack that fits in a hole on the spring perches, so the axle is always in the same position relative to the spring pack.
  3. achim1000
    Jan 14, 2003
    9
    Hamburg, Germany
    Thanks for answering! I didn´t expect an answer so quickly because it must be after midnight in the US!?
    What happens if the drive shaft was moved front or back, does it allow a little movement?
  4. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    shafts have to allow movement so the axles can articulate, how much depends on what type, /forums/images/graemlins/peace.gif
