And I Thought 4.10's and 42's was Bad...
Discussion in 'The Garage' started by SAVAGE1, Jan 11, 2003.
  1. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    And I Thought 4.10\'s and 42\'s was Bad...
    ...try 3.73's and 42's /forums/images/graemlins/eek.gif I thought I had 4.10's because of the numbers stamed into the ring gear-41 10, but after counting the pinion it had 11 teeth, making that 3.73's. I thought it was bad enough with 4.10's but 3.73's and 42's.. that sucked.
    Good thing is I am now on 5.13's and thew in a Detroit while I was at it. Talk about nite and day! I can now use all 4 gears in the 700r4 /forums/images/graemlins/thumb.gif At 65? i'm spinning at 1900rpm. I know my tranny is breathing a sigh of relief!
    The moral of this story- don't trust the numbers stamped on the ring gear, always count the teeth. I got the 14b from Pick N Pull so the owner of the truck probably had the pinion gear changed at some point and used the same ring gear. IIRC they used 41 tooth'ed ring gears for both 4.10s and 3.73's
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Re: And I Thought 4.10\'s and 42\'s was Bad...
    Yeah, they both use 41 tooth ring gears.
    41/10 = 4.10
    41/11 = 3.73
    Glad you like the 5.13s!
    -- Mike
  3. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    4.56s also use a 41 tooth ring gear, at least on my 14FF it does
    41/9 = 4.56
    Just so you know
    Will.
  4. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    /forums/images/graemlins/confused.gif so what is 45 / 11 ? 4:10 right?????? /forums/images/graemlins/confused.gif now ya'll got me worried ..
  5. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    45 / 11 = 4:10 right??????
    thats right /forums/images/graemlins/thumb.gif
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I'm about halfway through my 4.10 to 5.13 change with 40's. I'm glad to see that it was positive for somebody. /forums/images/graemlins/grin.gif
  7. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    a freind of mine had a ford with 3.55's and 42's but he dose have a 4speed and a diesal but dosent have a turbo
