And the Pile Grows
Discussion in 'The Garage' started by 78Suburban, Jun 29, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    4" RC fronts with 1" zero rates, ford towers, echbit flip, echobit heavy duty shackles. Raised steering arm and long brake lines are en route to my house :pimp:
  2. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    cool .
    where did you get the echobit flip ?
  3. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    got it used. Got it from pauly383k10, who got it from supersize.
    I've toyed with the idea of making some stencils of it, and getting a nice welder, taking some welding classes to sharpen up my skills, and trying to make some to sell, but I don't know if I'll ever have the cajonies to step out and make a busniess venture like that or not. The echobit style flip seems like a great idea to me. Its probably easier to install than rear lift blocks, and a great system :D I was happy when the big brown truck pulled up in the yard with it today :bow:
  4. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Sweet! how much coin are you in so far with the lift?
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I hear ya.. I have a pile a lot like that. No pic's, but the list is:
    D60 & 14BFF (w/ DL)
    D60 4.88 gears
    14bFF 4.88 gears
    Install kits d60/14b
    D60 Detroit Locker
    D60 1410 yoke
    14Bff 1410 yoke
    NP 205/241 MOD 1410 yoke
    NP 241 SYE kit
    14bFF rear disc brake brackets
    12 volt Air Compressor, on board
    Ford Shock Towers
    D60 U bolts/studs
    Longfield 300m axle joints
    moly 35 sp D60 inner shafts
    moly 35 sp stub shafts
    Warn 35 sp prem hubs
    Bolt in steering brace
    Hi-steer/X-over (arms, rod, d-link, ends, the usual)
    1” zero rates
    4” Shackle flip
    6” 48” TC EZ Ride front springs
    14 bolt plates
    Pro Comp 15.5” travel ES 9000’s
    Front Upper Shackle Bushing Kit
    Dana 60 Kingpin Spring and Bushing kit
    14B U bolts
    Caddy calipers for rear disc
    PSC Hydr. ram (on the way)
    Not too much more to buy...
  6. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Maybe its yours :p: :rolleyes: Sorry I just had to say that. I still cant believe that whole ordeal...
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have a pile , and its not all going in the truck :doah:
    My Parts List ..................Pauly383 . Not for sale , just for remembering what I got . Although some may go on sale later .
    Have and keeping for use or stocking :
    Chevy 10 spline np205
    Ford 31 spline np205
    2 various np203's missing some yokes
    2 np203's that are complete , one full time saginaw yoke , broken ,
    One part time flange known good .
    Flattop Knuckles
    Th350
    4.56 gears for 10 bolt and 12 bolt
    8 12 bolt shafts
    4 10 bolt front shafts 28 spline ( 4 long , 4 short )
    stock tierod just as bent as the old one before Marv tugged it too hard and bent it out LOL
    draglinks and pitman arms for 4wd GM's
    2wd 70's steering gearbox
    1988 complete 350 motor runs strong no smoke 110,000 miles from Blazekraze
    1987 .030 over 350 that needs a rering kit
    3970010 4 bolt block , machined , .030 over
    complete bottom end kit , .030 over with 274 cam
    882 casting heads , ported and rebuilt
    divorced choke quadrajet , Chevy ( have two now )
    hot air choke Quadrajey no bowl to can provision ( have two now )
    Electric choke Quadrajet with solenoid on the top , 86 K5 computer model .
    Holley 600 cfm vac secondaries manual choke
    Edelbrock performer .
    28 spline 10 bolt carrier open , needs rewelded
    28 spline 10 bolt gov loc , works
    30 spline 12 bolt 3.73 carrier
    3 sets of 12 bolt spider
    2 sets of ten bolt spiders
    Quic Loc for a 30 spline 12 bolt
    80's s-10 master and prop valve
    stacks of GM fans regular rotation
    sm420 2wd with 1350 yoke
    known good booster and master from 75 GMC p/u
    various 10 and 12 bolt yokes
    various hardware
    56 inch main leaf tops
    echobit flip kit
    All grey interior plastic ( promised to cmoe )
    All dash a/c vents
    lock motor
    new tan door panels painted grey
    New stainless brake lines for K trucks
    1970 Firebird front brakes from knuckles out
    80's master cyl/propvalve from ??????
    snow chains for 31's ( in AZ and I have no 31's )
    Will have after parts installed :
    3.08 gears for 10 bolts
    3.07 gears for 12 bolt ( there are NO 3.08 12 bolts )
    3.07 carrier for 12 bolt 30 spline
    Another set of 12 bolt spiders
    Stereo stuff NOT IN TRUCK(S) :
    4x10 Autozone speakers
    Blaupunkt 3.5 inch 2 ways
    Rockford Fosgate 10 inch 8 ohm 200 watt Punch Z
    Sony Casette deck with changer controls ( times two )
    Sony 10 disc changer
    2 six month old Dual 375 watt 10 inch 4 ohm Subs
    JBL 6.5 inch 2 ways
    Ford Taurus 6.5 inch stockers
    Old Kenwood 3 way 10 inch box with old Kenwood paper woofers
  8. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    crap, i thought i was the only one with the pile of parts problem. :doah: i have so much crap laying around but i can already see it all coming together on my blazer. since this is turning into a pile of parts thread, here's what i got :haha: :
    DRW 60 with detroit, 1410 yoke, 35 spline chromemoly inners/outers, 5.86s
    DRW 70 with detroit, 1410 yoke, 35 spline shafts, 5.86s
    SKY x-member
    52s for the front
    63s for the rear
    ORD zero rates f/r
    ORD shackle flip
    ORD HD shackle
    greaseable bushings all the way around...from ORD :eek1:
    SKY HySteer Kit
    2wd steering box
    new lug nuts purchased on ck5
    new wiring harness
    used steering column
    44" Boggers
    12" wide H1s
    propane setup & tanks
    new 60 u bolts
    SBC headers
    about 23 DosXXs in the frig
    203 range box
    & just waiting for my 203/205 NWF Doubler & 205 LoMax to get shipped so i can add to the damn pile...i just hate it when i have to deal with these piles, makes me miserable. :D well some of it should start coming together tomorrow. trailering my pile out to my buddy's shop to set up the suspension.
