Angle measurement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TheGeneral, Aug 31, 2001.
  1. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Question for measuring driveshaft angles. I have a angle protractor (floating needle type), just where do I measure angles at, and what is the acceptable tolerances in difference. I measured once already at pinion yoke and rear output shaft, got 7.5 at pinion and 8 and output shaft. Just want to make sure I am doing it right. Thanks for help.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    You need to take the shaft angle as a base. then you have to take the angle of the pinion. A good place for this is to place the gauge flat on the yoke flats where the ujoint caps bolt in. That will give you the pinion angle. Then you have to subtract the pinion angle from the shaft angle. This will give you the working angle at the pinion. Now do the same with the output shaft. If you have the slip yoke use the flat surface at the end of the output shaft as your angle surface! Then subtract that number from the shaft angle. Then compare this angle to the pinion angle adn these 2 numbers need to be within 2 degrees of one another.
    What is and what should never be....
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    the easiest flat surface on the dif is the machined surface for the inspection cover. depends on your trans case but any machined surface from the flywheel to the back of the transcase will be parallel to the output yoke. just to avoid having to pull the shaft.
    what is the current rule of thumb on differences? i think on the rear 4-6 degrees pinion down and the front 4-6 degrees pinion up. pretty meaningless numbers as what you are after is under power the difs to wrap to equal.
  4. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Agreed, but I'd rather pull the shaft than pull the cover off.[​IMG]
    tRustyk5 for President!!![​IMG]
  5. michaelm
    Feb 2, 2001
    872
    some difs the machined surface for the cover extends past the cover and gives an easy to use surface to put the angle finder
