angle of 3/4 ton rear axle.
Discussion in 'The Garage' started by Bobby Jennings, Feb 25, 2007.
  1. Bobby Jennings
    Bobby Jennings Registered Member
    May 8, 2006
    7
    california
    trying to find if anyone knows any degree angles for a ten inch lift for my rear 14bff axle. perches off and ready to weld on my new perches. leafs will settle i was told atleast an inch and a half. any suggestions will help in this project. thanks in advance.
  2. JNygard
    JNygard Registered Member
    Mar 19, 2003
    45
    Nampa ID
    With that much lift your going to want to run a CV drive shaft. So you will need to point the pinion directly toward the transfercase output, so your driveshaft has 0 degree angle with the pinion on the rearend. Of coarse with all the weight on the springs. You can adjust later with shims if/when the springs sag.
  3. Bobby Jennings
    May 8, 2006
    7
    california
    cv rear axle.
    i of course will run a cv axle in the front but i never thought of one in the rear. someone was saying i might have to clock my transfer case for the front. thanks for the info, this site is awsome.
  4. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    I'm running a 12" Superlift in my K5, and have a CV shaft for the rear. I also have 6 degree shims along with the tapered lift blocks to get rid of the vibrations.
  5. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    You may be able to get away with running a regular driveshaft in the back, although 12" is pushing it. Getting your angles equal at the t-case and the diff is extremely important. Here's how I did mine- I installed everything with the the stock perches in place. I made lots of measurements and figured the difference in degrees that the new perches would need to be welded on to match the t-case angle. In my case, it was about 23 degrees on both sides IIRC and my truck has zero vibes from the driveshaft. It's really just a lot of trial and error and I was fortunate enough to get it right the first time. Keep in mind, your probably gonna have to run 1410's at both ends= more $. If you haven't checked out the driveshaft 101, give it a shot. Good luck!
