Angle of steering arm
Discussion in 'The Garage' started by justwhatido, May 16, 2005.
  1. justwhatido
    justwhatido 1/2 ton status
    Apr 8, 2004
    1,037
    Mobile, AL
    I have been working on adding a block to the steering arm to level out the steering angle and everyone keeps saying that a two inch lift doesn't need one. This morning it hit me that I have the engine, transmission and transaxle on the shop floor. Could it be that the extreme angle is being caused because the front is higher because there is no weight?
    I think I'll wait till the drivetrain is installed before I install the spacer block to the steering arm. I think that the weight might cause the angle to be acceptable.
    Thoughts?
    Fred
  2. JNygard
    JNygard Registered Member
    Mar 19, 2003
    45
    Nampa ID
    Yes it will definitely change in height without all that weight. I would wait you should not need steering correction for that much lift.
