Angle plug heads and headers - who runs them both?
Discussion in 'The Garage' started by Topdown, Sep 2, 2003.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Ok... Who runs an angle plug head (other than me) and is running headers? What kind of headers do you run? 1st of 2nd gen?
    I need a new exhaust system, mine is rotting off as I watch it. I want headers and I already have the 2.25" pipe from LMC... Thanks in advance
  2. Topdown
    Nov 26, 2002
    2,598
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Why would you run 2 1/4 in pipe if you have a free enough flowing set of heads that they have angle plugs?
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I run them. The '88 K5 has the ZZ4 in it. I run headman hedders on it. I have no more problems with it than I do with any other spark plugs on other vehicles.
    John
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I run 2.02 angle plugs with Hooker Super Comp headers. They say they will not fit angle plug heads but they fit fine with regular length spark plugs and 90 degree plug boots (they probably wouldn't with the long straight plug boots).
  6. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    Keep in mind that there are variations of angle plug heads.
    On the Late GM aluminum heads, the plug insulators are only angled inward toward each other making most headers still fit well. Race type heads (Brodix, Dart etc.) have the plug insulator angled both inward & pointing down. These will cause problems with many headers.
    Which heads do you have?
    Hope this helps.
  7. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i ran some brodix angle plugs in a first gen. hooker has a part # special for that application. they were super comps w/ 1 7/8" primarys & 3" collecters. they fit great & plugs were easy to get to.
  8. Topdown
    Nov 26, 2002
    2,598
    Thanks for the input guys...
    I went out tonight and picked up a set of Hedman's. I will be running them to a 2.25" stainless system with original 40-series flowmasters.
    Why 2.25? so I can retain some amount of back pressure and low-end torque.
    Thanks again
