Angled Plug Heads ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lifethroughdeath, Apr 27, 2003.
  1. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    i've FINALLY rounded up enough cash to replace my rusted out, worn out, tired old stock exhaust system on my 90' K5 /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif, and i've already got everything i need, i.e. muffler, cats, pipe, etc... but in looking for headers i've found what i want, but they say they will not fit with angle plug heads and i have no f*cking clue what that means!! /forums/images/graemlins/confused.gif like i said my truck is a 1990 K5, 4x4 350 700r4. pretty much everything is stock as im the second owner (first was a chick) and i've only had it for a few months now. so if you guys could explain what that means, or if i have it or what, it'd be great, thanks alot /forums/images/graemlins/k5.gif
    nate /forums/images/graemlins/angryfire.gif
  2. KShortell
    KShortell Registered Member
    Jun 11, 2001
    44
    Bel Air, Maryland
    They might be referring to the spark plug wires with an angled spark plug boot. They might require that all cylinders use the straight-boot plug wire design.
    Hope this helps...
    Kevin
    /forums/images/graemlins/burb.gif
  3. swampblazer
    swampblazer Registered Member
    Mar 31, 2003
    49
    mass, u.s.
    dude. angled plugs refur to "camel back" or "camel hump" small block heaDS. these cyilender heads are a 2:02/ 1:60 confugration and were avalible on chevelles, corvettes, camaros... etc... but what makes these heads perform is the spark plug holes are drilled and tapped on an angle for more compltete spark burn. your header problem may refer to these style heads. which you dont have so NO you wont have a problem installing them.
