Angled Plug Heads
Discussion in 'The Garage' started by lifethroughdeath, Apr 27, 2003.
  1. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    i've FINALLY rounded up enough cash to replace my rusted out, worn out, tired old stock exhaust system on my 90' K5 , and i've already got everything i need, i.e. muffler, cats, pipe, etc... but in looking for headers i've found what i want, but they say they will not fit with angle plug heads and i have no f*cking clue what that means!! like i said my truck is a 1990 K5, 4x4 350 700r4. pretty much everything is stock as im the second owner (first was a chick) and i've only had it for a few months now. so if you guys could explain what that means, or if i have it or what, it'd be great, thanks alot /forums/images/graemlins/k5.gif
    nate
    /forums/images/graemlins/angryfire.gif
  2. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    the plugs enter the heads at an angle. the outside ends point toward one another kinda like:
    ------- <-- Engine center line
    that. hard to explain without begin able to draw a picture.
    -Ryan
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Excellent picture Topdown!!
    That is exactly how they are positioned in the heads. On non-angled plug heads, the spark plugs are exactly parallel to the front axle. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. Topdown
    Nov 26, 2002
    2,598
    I always wanted to be an ASCII artist! /forums/images/graemlins/rotfl.gif
  5. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    My '90 has the same drivetrain as yours, I don't have angle plug heads... You probably don't hafta worry about it. /forums/images/graemlins/thumb.gif
  6. hardcore71
    hardcore71 Registered Member
    Nov 21, 2002
    86
    Weare NH
    you prob don't have angle plugs. They are only found on some GM bowtie heads and some aftermarket hi-po heads. As far as I know the factory never used them on production vehicles and if they did it certainly wasn't on a K5
  7. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    The L98 (TPI) Aluminum Vette heads from approx 88-91 were angle plug heads. These will work with some headers, but not others as they are angled like the picture above. Also note that the porcelin end of the plug also angles slightly toward the ground on aftermarket heads, but not on the Vette Heads listed above.... they are horizontal.
