Angles and Carbs...
Discussion in 'The Garage' started by stockk5, Oct 22, 2005.
  1. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    I was wondering for you carb guys, at what kinda angles are u going up that your engine starts to flood? we talking like crazy stuff, like 45degree or more mellow?
  2. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    I havent had the oppertunity to take my truck off camber as I wish not too... trail riding and mud for me....
    supposedly my truck avenger is good for 45 degrees... also a magazine did a review of the truck avenger to which is why i got it. .they stood their jeep straight up... rested on the spair tire and it still ran... also laid it almost all the way on its side and still ran... so supposedly great for angles... I saw that people looked and didnt post so didnt want ya to feel like no one was gonna post... :wink1:
  3. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    I looked but didn't know the exact number so I didn't reply initially. I would bet that a regular quadrabog is significantly less than the truck avenger.
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    134
    The Q-jet is at least as good at angles as the truck avenger. It is widely considered the best carb you can have on a 4x4. And yeah, it can take 45 deg, I have never had mine die on me from it being at too steep of an angle (I run a Q-jet if you hadn't guessed, and I have done some REAL serious wheelin' with it i.e. every difficult trail in the Moab 4x4 book and then some). Seriously, Q-jets rock! :D
  5. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    And I've learned something new. I've generally not run a quadrajet in my drag racing experience because I find it easier to turn a holley. Thanks for the info.
  6. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    our group has holley-normal and truck,edlbrooks truck and normal and qjets.the best running ones are the qjets.have laid my jimmmy almost on its side-could touch the ground while sitting in itand have had the front bumper on the ground and is always ran fine.onlt time it has acted up is when it is bounced real hard.
  7. prossett
    prossett 1/2 ton status
    Sep 29, 2005
    165
    United Arab Emirates
    I just bought my rig (83 Jimmy) so I can't really tell 'cause I'm still working on the overall maintenance before really testing it out, but what I did do was a quick run on the sand dunes behind my house (easily 45 degrees, both sides) and the stock Q-jet did not cough once but there was a strong smell of petrol.
    Is the gas smell in the cab normal for a carb engine when at a sharp angle or off-camber? Where is it coming from and is there any way to make sure it's not dangerous? I drive in very hot weather, and fires are common.
  8. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    alright awesome! gives me more confidence in running the carb over tbi.. just cant afford 350 tbi stuff now. :)
  9. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    the 83 will have a bowl vent at the front of the carb, make sure someone didn't pull the hose off and leave it open, if they did, just plug it with a rubber vacuum cap, check to see if you still have the charcoal canister as well
  10. prossett
    Sep 29, 2005
    165
    Yes, from memory (it's night now) there is an obvious hose missing from the front of the carb - I can check carefully tomorrow. Where did the original hose go to and what was its purpose? To recycle gas fumes back in? In any case, I'll just plug it as you said.
    I do have the charcoal canister, with proper-looking hoses attached. Not sure where they run from/to but I'll check in the morning.
    Thanks - you guys are my link to sanity.
    Imagine that, my link to sanity is to a bunch of insane off-road guys!!! :eek1: :haha:
  11. dave_90_blazer
    Jan 1, 2004
    688
    IIRC, it somehow went over to the charcoal canister, and yes, just to recycle the fumes, to keep them from escaping to atmospere
  12. LVJimmy
    LVJimmy 1/2 ton status
    Aug 22, 2005
    301
    Lost Wages, NV
    Qjet
    I have run Q-jet's, Carter 625cfm, Holley 600,750, 850 and currently a 700. I have found the Q-jet by far to the best off road and not in just off camber but also just bouncing around the trail. With the Q-jet you never have to worry about keeping the RPM up so it won't die.
  13. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    I have the edelbrock 1406 IIRC and had some trouble with the bouncing off road. I installed their offroad kit which is spring loaded needles and havent had any trouble since with it. Angle wise I have never noticed any problems but I mostly do trail rides so dont take my word as gospel. I do know that my friends with holley street carbs, not the truck avenger, have had flooding problems. I guess if i did a carb again I would go q-jet and experiment with running it backwards, I have heard that this works well.
