angles for crossover....
Discussion in 'OffRoad Design' started by misfit, Jan 7, 2001.
  1. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    stephen, what would you consider the best crossover steering setup? tie rod over the springs? should the tie rod and drag link be as parallel as possible? i plan on using GM issue rod ends on everything where possible. any comments at all are appreciated.
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I really prefer to see the tie rod left under the spring and the draglink running all the way to the right knuckle. This gives you the longest draglink possible for the least bumpsteer possible. And keeps the draglink from rolling the tierod over everytime you steer it. Depending on how much wheel travel you have, spring thickness, crossmember configuration, etc, there may or may not be room for the tie rod to go on top anyway.
    With the draglink on top, you have to pay attention to the angles as the draglink goes into the pitman arm and the steering arm, but that's not that hard to sort out.
    There's my .02
    SW-ORD
  3. misfit
    Jul 21, 2000
    324
    im considering using dom tubing(probably around 1.5 od) for both tie rod and drag link, as opposed to solid bar stock. my existing tie rod only has one replaceable end(its a 74,on the pass side) also, how much are d44 flat top knucles and are they in stock?
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Heavy wall DOM should work just fine.
    We don't have any of the knuckles for sale outright, we can't find enough of them to sell so we do the machine work on customers knuckles and send them back.
    SW-ORD
