ANGLES?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AK-5GUY, Mar 16, 2003.
  1. AK-5GUY
    AK-5GUY Registered Member
    Apr 24, 2002
    89
    Greensboro, North Carolina
    I plan on putting an Echobit flip in the rear of my 1987 K5, and 4" tuff country springs up front. My question is, if I need correction shimms, will I need them for both the front and rear, or just the rear? Thanks.
    Harrison
  2. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    The shackle flip will rotate your pinion up in the rear. You can either shim it back down or go to a cv style driveshaft.
    You shouldn't do anything on the front. If you try to shim it, it will change the steering geometry & cause problems.
