Another 101 driveshaft question , really this one is a "dumb" one!
Discussion in 'The Garage' started by jakeslim, Mar 13, 2004.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Another 101 driveshaft question , really this one is a \"dumb\" one!
    Is it possible to have a driveshaft backwards? I mean does it matter(rear) which end goes to the tcase and 14bolt?
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    Re: Another 101 driveshaft question , really this one is a \"dumb\" one!
    normally you want the splines of the driveshaft at the tcase, it does not allow as much mud and dirt in the splines.
  3. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    ok, then i'm ok. I've seen them the other way though so it got me thinking.
    thanks,
    paul
  4. chevrules
    chevrules 1/2 ton status
    Aug 26, 2001
    127
    Canada
    you have probably seen them the other way when the truck had a rear CV shaft.....
  5. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    I spoke to Jesse (HAD) about this when he made mine, he said it didnt matter on a non CV shaft, some guys run the splined end at the rear to gain more clearance but mud and water getting in the splines is the problem. He recommended the splines at the front unless rock clearance was the only concern and spline life didnt matter.
  6. chevrules
    Aug 26, 2001
    127
    Canada
    I agree,i was just stating that he maybe saw a shaft reversed with a CV....I run my slip at the bottom,don't care about carnage....brings a big smile... /forums/images/graemlins/grin.gif
  7. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    I run mine with splines to the front but if I start denting the shaft on rocks Im swapping it /forums/images/graemlins/thumb.gif
