Another 14 Bolt FF Question
Discussion in 'The Garage' started by trollporter, Mar 25, 2004.
  1. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    I have located 14bFF in a late 70's SRW 3/4 ton 2wd. Is the spring perch center-center and the WMS-WMS correct for my '84 /forums/images/graemlins/k5.gif. I'm fairly sure it's the right one but I just want to make sure. And is $200 at a salvage yard a good price? /forums/images/graemlins/thinking.gif
  2. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Not too sure about that price...I picked one up last week for $50.
  3. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    The spring width and wms are the same as your current axle. The 2wd versions' shockmounts are about 1.5 - 2" lower on the axle tube but are on the right sides. I would pay $200 for a 14B FF in good condition.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Yup.
    Not a bad price...especially if it's got the gear ratio you want and doesn't need an overhaul before you can swap it in.
    Being from a 2wd, the shock mounts will be about 2 inches lower than the 4wd version. This gives you a couple of options. One, you can just hook up you current shocks and you'll loose some axle droop in articulation. Two, you could cut and re-weld the shock mounts. Or three, buy some longer shocks.
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    If it's in good condition then 200 clams sounds good, but if need a lot of work then get 'em to lower the price...
  6. trollporter
    Feb 29, 2004
    518
    Lady's Island, SC
    Thanks for the input guys. The axle appears to to be in fair condition from what I can see and I'm not sure about the cog ratio. Can't find a ratio tag like some of the others that I've seen. And the shock mounts aren't that big of a deal because I'm going with Mossouri Off-Road shock over axle set up, I think i'll get a little better arc out of the suspension. I need the top spring plates too, right? /forums/images/graemlins/thinking.gif
    The 200 Beans dois sarting to sound like a little high.
  7. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    Pull the cover and count the teeth. Divide the big one by the little one and get your gear ratio. The ratio is also stamped on the ring gear. That will also let you check the condition of the internals and find out if it is a open carrier, gov-loc, etc... Offer 'em $100 if it looks to your liking. I got a open-carrier, 4.11, 14BFF in good tight condition at a pull-a-part-yourself place for $75. Save yourself some trouble and get the springplates and ubolts. Good luck /forums/images/graemlins/thumb.gif
  8. 4x4mike
    4x4mike Registered Member
    Mar 25, 2004
    16
    Sacramento, California
    I am in the process of rebuiling a 14 bolt to replace my 10 bolt. The spring percehes are the same. My 2wd 14 WMS is about 3/4 shorter than that of my stock 4wd 10 bolt. The brakes are much bigger and with after market wheels with different backspacing I should noitce no difference.
  9. trollporter
    Feb 29, 2004
    518
    Lady's Island, SC
    Thanks, this is some great info. Will 15" rims fit over the drum? /forums/images/graemlins/thinking.gif
  10. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
  11. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    15" rims will fit, and it's an 8 lug axle?
