Another 14FF Disc Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by white-rhyno, Apr 10, 2002.
  1. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    For all you guys our there with the disc conversion, can you still run a 15" wheel? Can the calipers be ground like the front? Doing the conversion soon but might change my mind if I cannot run 15's. Or possibly a differnt offset??
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    You dont need to grind the calipers with this conversion to run 15" wheels.
  3. white-rhyno
    Jan 27, 2002
    942
    Thanks, I guess I will go for it then.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I got a question about Disc swap too. (sorry to take over your post) What type of brake lines does the rear conversion use? Does it use the original hard style lines the run along the axle, or the soft lines like the front. If anyone has pics I would appreciate it. Also, what is the total cost for the conversion? Thanks
    Harley
  5. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    Hoss,
    i used the front d44 soft lines on my rear caddy calipers. i had to grind part of the ear off to position it correctly. the caddy line is solid and the block that bolts onto the caliper is just plain squarish. the d44 line has 2 ears on each side.
    ARQ.
  6. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    I took some measurements and went to earls and peiced together a complete new braided steel line setup.. new banjo bolts, fittings, etc, it cost me about $65 out the door.. I could even post the part #'s if anyone wanted... Ill take pics asap
    mike
  7. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Go for it, we can link your post if anyone ever asks again.
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Pics would be great. I am a very visual person so pics would be the best thing for me to understand fully how the setup and swap is. Also if you could get some pics of your disc setup that would be great too. I am thinking about going to a disc setup when I swap my 14bff in. If I need new drums for my axle I will most likely be going disc.
    What all parts are involved? New rotors off a 3/4 ton D44, el dog calipers, disc brackets, and lines? What other calipers can I use with the setup? Can I use D44 or 10 bolt calipers? Thanks
  9. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Ok I think I am getting on the right road now...
    I am looking to go a bit beefier on my axels (1979 K5)
    I should look for the 14 bolt FF off a 3/4 ton 2x or 4x4 truck or sub
    What should I look for in a front axel? Should I get the one off the same model of truck or should I get one off a different model of truck? What model of axel would that be?
  10. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    Harley,
    Go for the disk brake setup, it's cheaper than replacing the drums. Get the bracket's from misfit and the reset of the parts from autozone. I haven't finished the conversion yet let alone the 3/4 ton axle install but I figure do it right the first time and be happy with the results. If you need any help let me know. That's is if your in town....
    Mike
  11. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I will be back in a month. Then I am going to start redoing th 14bff. I am buying DesertDuelers front axle with a lockright and 4.56's, and he is going to install my 4.56's in the 14bff and weld it. So everything is looking good at this point for some major wheeling during the summer. Just got to get the cashflow up.
    Are you using the El Dorado calipers for you 14bff? If so how much did autozone have them for? What year are they off of?
  12. tomnits
    tomnits Registered Member
    Nov 27, 2000
    17
  13. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Thanks for the pics. Now I understand alot better. If I use the El Dorado calipers is there the provision for the ebake on there? I use my ebarke once and a while, and would like to keep it if at all possible.
