ANOTHER 14FF Disc swap question: Stud part #
Discussion in 'The Garage' started by alaskatoy, Jan 17, 2006.
  1. alaskatoy
    alaskatoy Registered Member
    Dec 4, 2005
    7
    ohio
    I've been searching and thought I had it all figurered out. I wanted longer 9/16 studs for the swap, and to help facilitate running aluminum H2 wheels. Shakerbuilt's site says studs from a dually 14 bolt will work. So I found Dorman p/n 610-194 from www.rockauto.com listed as a 1985 rear stud for a DRW axle. I got them today; the knurled area is too small and drops sloppily into the rotors (p/n 5014, raybestos for a 76 K2500) and the shoulder or flange is far too fat. So obviously *any* dually stud won't work. Does ANYONE actually have the p/n for the proper stud for this application? thanks.
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I have never had a stud fit tight to the rotor. Tight to the hub yes. Tight to the rotor no.
  3. alaskatoy
    Dec 4, 2005
    7
    ohio
    these rotors are staked on with the studs behind the hubs. They don't slide over the studs on the front of the hub. These studs should be a press fit.
    Anyone got the right p/n?
  4. alaskatoy
    Dec 4, 2005
    7
    ohio
    OK; can anyone tell me how the thickness of the stock drum is where the studs pass through?? The rotors I have are 1cm thick. If the drum is the same or thicker, I can live without new studs. If the drum is less than 1cm, new studs are mandatory.
  5. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    i just swaped in rotors from a 76-78 ish front 3/4 ton in my disk swap. i used the dulley studs. my rotors didnt center with the studs and i have over 5k miles on them now with no problems or vibrations.
    some rotors are cut with a relefe and some are flat. you might need to grind down the head of the stud just a bit to let it seat in the flat spot in the rotor.
  6. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    of the 5 axels I have swapped to disc I used the front studs on the rear.
  7. alaskatoy
    Dec 4, 2005
    7
    ohio
    Front studs from what? A K3500, or a 2500? Dually or non? Thanks.
  8. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    78 2500 burb since that was what my axels were. basicly I run 32 of the same studs on my rig.
  9. alaskatoy
    Dec 4, 2005
    7
    ohio
    studs need to be 3" min. K20/25 front studs are all too short.
    k20/25 rotors are designed to run hub-centric on the back of the k20/25 hubs; so stud hole size on the rotors is not a big issue. The 14 bolt drums have a much smaller center bore than the K20/25 rotors do, so the rotors CANNOT seat hub-centrically on the back of the 14 bolt hubs. SO the best hope is that they can be staked lug-centrically to the hubs. The problem is the stud holes in the rotors are about .630ish". The commonly recommended dually studs are only .620-.622 - they are sloppy in the rotor holes. This means the rotor may not center on the hub. Not to mention grinding the heads on 32 studs sucks. I finally sourced a stud for a ford application that come closest to meeting all the needs of the above. Dorman 610-301 is 9/16-18, 3-1/4" long with a .622 knurl, but necks up just before the head. The portion that necks up seats in the rotor MUCH better; not a press fit, but not sloppy like the regular dually recommendations like 610-189 and 610-194. Plus the 610-301 head size fits into the relief in the rotors and requires no grinding. $1.99 at autozone, $2.48 at Advance, and $3.49 at Napa. Pix later. HTH someone someday.
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    so technicly my rotor should pull right off of the studs? (.622 vs .630) cause they don't. I have had to pound all 64 studs in (4 axles)
    what rotor you using???
  11. alaskatoy
    Dec 4, 2005
    7
    ohio
    Uh no. I don't think I was clear enough, I guess. The head of the stud would obviously make what you suggest impossible.
    Raybestos 5014, 76 K2500.
  12. alaskatoy
    Dec 4, 2005
    7
    ohio
    Left to right (dorman part #s):
    610-301.....610-194......610-189(stock rear stud 89 GMC K3500 SRW)
  13. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    ok so have anyone decided which stud is the best here? Get the long one with large head and turn it down or the small head? I used to have a thread from pirate bookmarked but lost it and now I need to get studs this week and can't find the info I was lookin for.
  14. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    The middle 1 looks like the right part.....I used my old studs from the drums, I was careful when I smacked them out, then I used a thread chaser on each stud and they were like new.
  15. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Not entirely sure what the problem is. As far as I know there are only two studs that work for the 14BFF. SRW and DRW. The studs are not supposed to be a tight fit to the rotor.
    As far as the head being too large, sounds like the rotor is wrong or the stud is wrong. There should be a recess on the backside of the rotor for the head of the stud to drop into. Its approx. 1/4" bigger diameter relief than the head of the stud when using the factory studs or the factory DRW studs. I'm running the SRW studs that were in my axle when I acquired it. I believe Stomper is running the DRW studs. Most probably using the studs they knocked out when doing the swap.
  16. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    I currently have the stock drum studs in mine but there is only maybe an inch if that pokin through which worked with the steel wheels but isn't with the aluminums. I may knock one out and turn the head down so it fall into the reliefe but I dunno if I will gain enough
  17. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I'd have to say probably go with the DRW studs. They are the same in the spline length and shoulder size and all that. Just way longer thread. 4" something like that.
    Can you shoot a photo of the back of your rotor with a stud sitting in the hole? like the photo that was posted earlier in this thread?
  18. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    yeah I'll try to get one tomarrow. I put the axles in the 71 today but I'll try to see if I can get a clean shot of it. Another local guy took his studs (metric ones so he could use special slined lug nuts for his deep holes alumin wheels) and had the heads turned down to fit in the relief. I think I could stuck a stud in the drill press and spin it and lightly grind the head down (insert redneck lathe)
  19. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Yep, I've got the DRW studs and they are supper long. 1/2" thick wheel centers, over an inch of lug nut and there is still over an inch of thread past the nut.
  20. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    at that point I hope my bling chrome lug nuts wouldn't bottom out. They are like 3" long. The ones you use look like the center ones in that pic above?
