another 700-r4 problem......
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by alexlong, Feb 29, 2004.
  1. alexlong
    alexlong Registered Member
    Feb 29, 2004
    10
    College Station, TX
    the 700-r4 in my 85 K5 is acting like it is, simplt put, slipping. It is a little more extreme than that though, it only does about 15 mph at 3000 RPMs, and only that fast really b/c it carries momentum. Any ideas before I get into it?
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    What gears did you lose? Do you have reverse? Sounds like you broke the splines on the sun gear. Time for a rebuild.
    You will need an aftermarket thick sun gear.
  3. alexlong
    Feb 29, 2004
    10
    College Station, TX
    I didn't actually lose any gears, they all act like they are barely "catching", like there is no power going to the wheels. It shifts just fine, but no power transfer
  4. alexlong
    Feb 29, 2004
    10
    College Station, TX
    Also, Advance Adapters is closed today, and I was wondering if anyone knew if they make an adapter to put the NV4500 onto an NP208?
  5. 4wood
    4wood 1/2 ton status
    Jul 27, 2003
    116
    Atlanta, GA
    I have a 700r4 in my 87 K5 and it has been acting up similar to yours lately too. I had the governor replaced and that helped (at least for a little while). The problem has come back and I'm not sure if that means that 700r4 trannys just eat governors for breakfast, or if it's just so old it needs to be rebuilt/replaced? At any rate, try the governor and see if that helps.
  6. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    Slipping? Possibly torque converter but not likely, it might be the pump in the transmission going out and not providing enough pressure.
