Another 8 lug conversion ?
Discussion in 'The Garage' started by BigMac, Aug 5, 2002.
  1. BigMac
    BigMac 1/2 ton status
    May 27, 2002
    397
    Fremont, CA
    I didn't want to hijack uglychevy383's post about his conversion to 8 lug...but I have a similar question
    I picked up my 14 ff this weekend and have begun converting it to disk brakes...
    So now I need to think about my front conversion...
    I have a 72 k10 that needs more brakes in a big way..
    My question is where does the 72 dana 44 fall in to the year breaks? ? Are the 72 1/2 ton spindles compatable with 3/4 ton hubs?
    72 and 73 did use the same brakes didn't they?
    Heres what I think I need... thats what gets me in trouble,,,,thinkin...
    73 3/4 ton backin plates 2
    73 3/4 ton rotors F&R 4
    73 3/4 ton hubs 2
    73 3/4 ton studs
    73 3/4 ton calipers (for rear) 2
    bearing seals and grease
    oh yea wheels and tires
    so am I totally off or have I figured it out?
  2. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Martin,
    The only thing I can see is where you say 3/4 Ton HUBS, you should be saying SPINDLES....that's the part that all the bearings ride on, and that your retaining nuts and washers will screw onto.
    That will help people understand you better when you start begging them for parts! /forums/images/icons/grin.gif
    There is a change in the spindle design, and Wes (ThatK30Guy) knows this stuff in his sleep. The only thing to remember is that the rest of the parts you buy need to match the year of the spindles because there are slight differences and the parts won't mix and match.
  3. BigMac
    May 27, 2002
    397
    Fremont, CA
    Actually, I was reading in another thread about this that the spindles 1/2 & 3/4 ton in 73 were the same. The difference being the hub. I kinda need to know if the spindles changed from 72 to 73. If I had a 73 I wouldn't need to change the spindles , just the hubs , backing plates and rotors. If I'm wrong, thats ok... I'd so much rather be wrong here than at the parts store...
    On a side note.... that rear end is ALOT lighter without the drums and hubs on it...
    So hows that steering comin? You gona put that on the 44 or the 60?
  4. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    The 60.....it's ALL-OR-NOTHING on these Moab preparations!!! /forums/images/icons/shocked.gif
  5. BigMac
    May 27, 2002
    397
    Fremont, CA
    dang! you musta read it while I typed it
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    You can use any 8 lug parts to bolt onto your '72 axle as long as the 8 lug parts fall in the years BEFORE 1977.
    Your '72 is classified as the same as the '73 - '76 "first design" axles and therefore will interchange parts very easily. /forums/images/icons/wink.gif
  7. BigMac
    May 27, 2002
    397
    Fremont, CA
    Yeehaw!
    So theres two things I dont need!
    Now to begin collecting the parts.
    thanks thatk30guy
  8. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Like I said......WES is THE MAN! /forums/images/icons/laugh.gif
  9. BigMac
    May 27, 2002
    397
    Fremont, CA
    What can I say, you were right. Wess is da man!
    I think I managed to not buy parts I dont need! This is a first!
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    /forums/images/icons/blush.gif /forums/images/icons/blush.gif /forums/images/icons/blush.gif /forums/images/icons/blush.gif /forums/images/icons/blush.gif /forums/images/icons/grin.gif
    Thanks for the kind words! /forums/images/icons/wink.gif /forums/images/icons/cool.gif
  11. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    highjack all ya want, im no fawkin whiner /forums/images/icons/grin.gif /forums/images/icons/grin.gif i think we both need info, so bring it on baby /forums/images/icons/grin.gif lol, at least it didnt take you 2 days to get your first reply lucky dog!
    good luck, Rob.
  12. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    It's all true...you've helped me out every time I've asked, and always with correct and timely info.
    BTW -> I found out last night that my d60 spindles are kinda chewed up (Bad bearings scored the seating area, and the stub shaft rubbed and mushroomed the end of the spindle tube.....
    I don't even want to think what a NEW set will cost (Do I?) so I thought I'd ask you first if you had a set that are correct for a '80 D60.
    Man, my luck gets worse and worse these days...... /forums/images/icons/crazy.gif
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, I have 3 pairs of spindles....1 pair will cost you mucho $$$$ since they are still bolted to the truck!!! /forums/images/icons/shocked.gif /forums/images/icons/laugh.gif /forums/images/icons/grin.gif
  14. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    What about the other 2 pairs?.....
    I'm serious, I need to locate parts....either good used or NEW ($$$$)
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    Those other 2 pairs are also bolted to the truck, too. /forums/images/icons/laugh.gif
