Another Air compressor idea.
Discussion in 'The Garage' started by gzzgfw, Dec 22, 2003.
  1. gzzgfw
    gzzgfw 1/2 ton status
    Feb 26, 2003
    505
    Here is another compressor idea using suspension leveling compressor from vechicles with auto leveling suspensions.
    Has anybody done this, does it work for large tires.
    Seems like a good idea since it is all electric!
    http://www.redbirdsra.com/techtipscompressor.htm
    -Mark
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I have one of those compressors in the garage, waiting for some experimentation. /forums/images/graemlins/cool.gif
    Since they came on luxury cars, I'm guessing that it will be pretty quiet. But all they fed in the stock application was a couple of air shocks. That is a high pressure, low volume application. So I'm thinking it will be only slightly better than one of those noisy little compressors that plug into the cigarette lighter when it comes to inflating large tires. However, if you add a storage tank and an automatic pressure switch then it might prove to be more useful. /forums/images/graemlins/thumb.gif
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Those were the trick deal on the ORC toyota list about 3 years ago. Most ran at least 2 of them in parallel, some were up to 4 of them.
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Hmm, I hadn't thought about running multiples. They're certainly cheap enough to get! The local pick-n-pull gets $10 or $15 each for them. /forums/images/graemlins/cool.gif
