Another Auto/SM Tranny Swap Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by noahrob, Dec 7, 2005.
  1. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    Hi,
    Let me start by saying I have used the search a lot before I even thought about asking a question...but here it is...
    When going from a TH400/205 to a SM465/205, will new holes need to be drilled in the frame to accept the crossbrace bolts since the transmissions are different lengths? I am thinking that with the bellhousing et al...I might actually be on the money, but just thought I would ask.
  2. ccj8008
    ccj8008 1/2 ton status
    Apr 2, 2001
    228
    Polson MT
    When I replace a th350 with an sm465, I had to drill new holes. HTH's.
  3. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Cool, thanks, I will be ready with the drill just in case. A few other quick questions.
    1) Where can I get that Z-bar bracket?
    2) Where can I get a clutch pedal assembly rebuild kit (busihings, springs, etc..)?
    3) Are the bolts that hold the tranny to the Bell housing 7/16 grade 8? I saw one post indicating they were metric, but that doesn't make sense on a 1973 Chevy...does it?
    Thanks to anybody willing to help out.
  4. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    anyone?
  5. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    the bolts should be 3/8". the other stuff you'll need to find 'em out of a yard or other donor truck(most likely). don't forget there's also a hydraulic clutch, too that you could go with.
  6. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    The z-bar bracket you'll probably need to get from a yard.
    The pedal rebuild stuff, and the z-bar components (there's balls, seals in there too), I have a GM parts manual and I ordered each individual seal and bushing etc from GM. Ended up costing like $50 in the end (and I already had the Z-bar!). I'm away from home right now, or I'd post the diagrams and part numbers, but if you go to a dealer, they can still get all that stuff. I Even got a new rod (the rod from pedal to Z-Bar), as the ends of mine were worn so bad, they were about half the diameter they should have been, creating alot of slop.
  7. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    There are a couple of valuable resources for small obscure parts like pedal bushings. I suggest getting catalogs from LMC Truck and ChevyDuty. They have combined to supply me for many 80's pickup restorations.
  8. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Thanks, you guys have been great and the support has really helped. I am going to order the little parts(bushings etc...) for the pedal assembly as well as the Z-Bar setup tomorrow.
  9. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Smart move. Alot of people wonder why they're pedal is so loose and clutch feel gets vauge, and alot of it has to do with this little bushings and the ball joints on the Z-Bar.
  10. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    One more dumb question (for now) does the Z bar bolt to the block right above the oil filter or the Bellhousing?
  11. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    One end bolts to the frame the other sits in the ball on the bell housing.
  12. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Yep, to the bellhousing. Bellhousing will have stub for a screw in ball on the drivers side.
