Another BB 454 question
Discussion in 'The Garage' started by Thumper, Jun 21, 2004.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I am searching for a flywheel... not a secret /forums/images/graemlins/smile.gif.
    A lot of them say they are for either a 'internally or externally balanced 454'. Which are which? How can I tell which it is? Is there an easy way? Or is there a range of years that apply to each type?
    Mike
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    AFAIK all production GM 454s are externally ballanced. some of the aftermarket cranks are internally ballanced. thats all i know.
  3. stretch67
    stretch67 1/2 ton status
    Nov 1, 2003
    171
    bozeman mt
    all factory 454's are ext balance. that is the flywheel you need. any application from 75-90 should work. not sure if chevy changed crank hub pattern after that. get the one for the 11" clutch!
  4. Thumper
    1,582
    Alberta Canada
    Awesome! Thanks a lot.
    Mike
    /forums/images/graemlins/thumb.gif
  5. stretch67
    Nov 1, 2003
    171
    bozeman mt
    /forums/images/graemlins/waytogo.gif
