Another bluebie 14FF ?
Discussion in 'The Garage' started by deothrwhtmt, Nov 10, 2002.
  1. deothrwhtmt
    deothrwhtmt Registered Member
    Feb 24, 2001
    61
    Maryland
    What is the widest 14FF avail? And what can I pull one of of? Contemplating running Hummer wheels without the center mods. DRW D60s are easier to find than SRW also.
    Lastly, will I need to drop my tcase after I install a 12" lift? /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
    *nudge* Fr8train *nudge* /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Hummer wheels of any backspacing can be had by calling Daniel at USA 6x6 for $165.
    You can find a duallie D60, and machine it down.
    Lastly, the widest 14BFF availible is out of a van. they would be 3" wider, and match the front width. or you can get spacers.
    I could comment more definitivly, but your profile is not filled out...
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    If you need a wider dually axle, locate and use the D70 dually rear out of fleetside K30's with duals. These D70's are wider than any 14FF available.
  4. deothrwhtmt
    Feb 24, 2001
    61
    Maryland
    Well dont plan on running any sort of mod. Hummer wheels. I dont want anything bad happening period. I have a Phd. in Murphys law. Filled out the profile though Zakk, thanks forgot to do it /forums/images/graemlins/1zhelp.gif. Wes, thanks for the advice. Are the D70 rears going to have the same ground clearance as the 14FF? Arent there a bunch of D70 versions out there? Which one do I want to go with? Also are disk brakes kits avail for them?
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    You can get a super-wide 14-bolt from a 93-up DRW van, 92-up DRW pickup (cab & chassis type is narrower) or 92-up DRW walk-in van.
    I'd stick with the 14FF just for the cheap Detroit.
