Another Body work ? How do you remove the pin stripe?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Esteban86K5, Jan 12, 2002.
  1. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    So I'm in the process of doing some body work to my truck so that I can paint it. Well I have that dreaded pin stripe all along the side of my truck. You know the one that like an inch wide and is ugly as hell. Well I tried to scrape it and then tried to sand it and that thing is on there good. What have you guys used to remove it? I don't want to go out and buy different chemicals that may or may not work. Any ideas would be greatly appreciated. Thanks.
    <font color=blue>It's easier to teach a child than to fix an adult.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/user/geltyone>Webshots Pics.</a>
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Eastwood has some rubber eraser thing for a drill that is suppose to remove that stuff.
    Bubba Ray Boudreaux,
    Official Colorado K5.com Fantasy Football Choke Artist!<a target="_blank" href=http://community.webshots.com/user/mdntrdr1>http://community.webshots.com/user/mdntrdr1</a>
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    If it is the decal type... You can use a heat gun.. It will warm up the glue so it will scrap right off. Before you go out and by a heat gun. You could try it with a blow dryer on a small area.. If it works go out and buy it.. There like $25.00 at any hardware store......Dan
    If it ain't broke.......Don't fix it....
    <a target="_blank" href=http://coloradok5.com/gallery/Gokartergo>KLICK</a>
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Steph's Webpage&gt;&lt;&gt;
    Suck Fumes Ford Boy
    I'm in shape.... round is a shape......
  5. Esteban86K5
    3,712
    Bakersfield, CA
    So I go back outside after I write this post and remembered that I have a heat gun. So I whip it out and start too use it. Well it gets the pinstripe off but it leaves the adhesive there. So I guess now all I have to do is get some acetone and remove all the adhesive. The heat gun worked a little slow, but I think sanding would have been slower. Thanks for the suggestions. Now I gottta go back to work.
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    rubbing alcohol will get rid opf the sticky stuff left over. cheaper than the acetone.
    nathan
  7. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Have fun. I just went through this with my Suburban. Luckily only on the new doors. That sticky stuff was A PAIN to get off. Acetone wouldnt do it easily like I thought. Lots of rubbing.
    Ken H.
    '86 K5 in parts
    1-ton 454 44 TSLs
  8. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    for the glue residue left on there I would use Goo-Gone or OOPS or some other chemical you can find in your local discount store paint department. I like the goo-gone best! Next time you remove stickers or pinstripe from any car with heat...do it slow, take your time, and allow the glue plenty of time to get hot and most of it will peel off with the sticker or pinstripe. Then use a little elbow grease to get the remaining residue off. There should not be to much if done properly!
    Justin
    Austin, Texas K5'er
  9. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Nonesuch...
    I am all done and already did this. Should reply to the correct person.
    To add on... I did use a heat gun and did allow it to wam up. The paint would actually bubble before I was able to wipe off the sticky stuff. Goo gone did noting for it at all. Goo gone and such products are no match 20 year old original pinstriping.
    Ken H.
    '86 K5 in parts
    1-ton 454 44 TSLs
  10. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Esteban I have an air grinder with 36 grit sand paper. That might work. I'll even volunteer my 4 year to do it for you.
    See you tonite (I hope).
    Richard
    <a target="_blank" href=http://community.webshots.com/user/chvyhs>WebShot Pics</a>
  11. scotty1
    scotty1 1/2 ton status
    Jan 7, 2002
    166
    WV, Harpers Ferry
    Astro Wheel, get them at any body shop for about $10. You will need an air drill to spin it fast enough, basicly it is a big disc shaped pencil eraser.
    Git there fastest with the mostest!
    Nathan Bedford Forest
  12. Esteban86K5
    3,712
    Bakersfield, CA
    I know what you mean about it being a PAIN Ken. I had some acetone in the garage and attacked it last night and it didn't come off as easy as I thought it would. The paint did bubble a little with the heat gun and I think I was taking off more paint than glue at one piont. Which sucks cause now I have to deal with that. I've got some Isopropyl Alcohol that I'm gonna give a try with.
    Thanks all for the replies and the help.
  13. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    I don't have a heat gun but i got my acetyline torch to melt the glue!!!!
    NO LOCKER, STOCK GEARS, NO PWR BRAKES, NO POWER STEERING, NO PROBLEM!
    HIT IT FULL CHICKEN!!!!
  14. Esteban86K5
    3,712
    Bakersfield, CA
    I said melt the glue, Mike!!!! Not the METAL!!![​IMG][​IMG]
  15. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I took mine off with a pressure washer. Took off the decal and adheasive...no residue or 1000 clogged sanding pads
    DRIVE IT LIKE ITS YOUR BOSSES!!!
    Luke
    84 K5
  16. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    I removed some old stripes once. I used a heat gun to get the stripe off, and then 3M Adhesive Remover for the glue residue. I tried many methods, but I thought this one worked the best. Most hardware stores carry 3M Adhesive Remover. Test it on your paint first to make sure it is compatable.
    I haven't heard of a pressure washer being used for this before. It might be worth a try.
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
  17. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Listen to Gandolf, the 3M adhesive remover is what we used to "dechrome" many trucks with the stick on emblems and stripes, works great.
    Rob
    <font color=orange>Bleedin' Chevy Orange</font color=orange>
  18. Rob 85K5
    1,487
    Pensacola, Florida
    Rob
  19. Esteban86K5
    3,712
    Bakersfield, CA
    I used the heat gun and then I applied the 3m adhesive remover with no luck. The acetone worked better even though it was still slow. How old was the vehicle you used it on. Maybe that's the problem. My buddy used it on his NEW truck to remove the adhesive form his trim and it worked pretty good. Mine are just stubborn[​IMG]
  20. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Try a little lacquer thinner on the stripe glue.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
