another broken ring gear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Yuba K5, Oct 27, 2002.
  1. Yuba K5
    Yuba K5 Registered Member
    Jul 31, 2002
    31
    marysville ca
    i listed a post a couple of weeks ago when my truck started thumpin.it was the ring gear.it hasnt been a year since i had the locker and 456s put in the damn thing.is this some sort of crazy bad luck or just what i should expect from a 10blt? i am running 35in tires,but have mostly kept in on the street except for one weekend in the sand.i am wondering if the place that did the work may have screwed up the lash. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    10 bolt + locker + 35" tires = broken 10 bolt.
    My buddy has gone through 3 10 bolts in the last year.
    He finaly swapped in a 14 bolt SF.
  3. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    if you decrease the backlash a bit and increase the carrier preload it will help to stop the ring gear breakage but it's not really good for a highway driven truck.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The gear teeth start getting pretty small when you get to 4.56 gears in a 10-bolt. /forums/images/graemlins/frown.gif If you have a heavy right foot, you don't need to go off road to break 'em. /forums/images/graemlins/wink.gif Sounds like it's time to upgrade to a beefier axle. If you can find a 14 bolt single floater axle with the 6-lug bolt pattern, you'll have a pretty beefy setup and won't have to buy new wheels. Or you could have Donovan modify a 14-bolt full floater for 6-lugs and never have to worry about breakage again. /forums/images/graemlins/cool.gif Or go all the way with a 14 bolt full floater out back and convert the front end to 8 lug and buy new wheels.
