Another caddy caliper question
Discussion in 'The Garage' started by Ryan B., Oct 16, 2002.
  1. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Well someone posted that the caddy calipers to look for are '76-'78 caddy eldorado calipers...
    Today i found some calipers off a '79 caddy seville.
    They have all the ebrake stuff complete, with the spring and lever and such... Are the '76-'78 the ONLY ones that will work?
    I think tommorow i'll go back, unbolt that caddy caliper, then take it over to a chevy truck and try to bolt it on the D44 front i saw at the junkyard.
    How much is a typical core charge for these calipers at the auto parts stores?
    Thanks /forums/images/graemlins/thumb.gif
  2. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Interestingly enough the core charge at my local parts house is like 15 bux. Not even worth getting cores for.
  3. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    The rotors for the caliper you refered to are thinner than the 3/4 ton front rotors that are used with the 76-78 El Dorado calipers.
  4. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    jeffro,where are you getting yours from???A Z wants $80.00 core
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The '79 calipers open about 1/4-inch less than the 76-78 calipers. /forums/images/graemlins/mad.gif
  6. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    i checked 2 or 3 places and th ebest i found was national auto with 80 dollars for the caliper,15 core plus tax.thats where im getting mine.i called other stores and napa was the most expensive with 75 dollars caliper,65 dollars core plus tax.so if you call around your bound to find a good price.
  7. jeffro
    Jul 2, 2002
    406
    Scurry, TX
    Motor parts in Kaufman. 80 bux for the Caddy caliper, 15 dollar core. Conversely, the 3/4 ton front is like 29 bux with a 50 dollar core. Since I have cores I opted for the non-ebrake calipers and will install a driveline park brake. I think it will be a cleaner application without the cables hanging down to the hubs.
  8. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    the drive shaft conversion ebrake costs a good amount of money i have heard unless you can build it yourself.id like to go that way but too mauch money for me.
