Another call out to those Rancho 9000 users
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bigmeats, Aug 28, 2000.
  1. Bigmeats
    Bigmeats 1/2 ton status
    Jul 29, 2000
    523
    Manhattan IL
    Hello all,
    I just received my Rancho 9000's and the remote controll for them.
    My question is how long should i set aside to install the system, and is there any special tricks i should know about?
    Should i worry about the air lines freezing in the winter due to moisture from the compressor.
    Does anyone use an antifreeze for compressor lines?
    I am thinking about running all the air line through plastic wire lume for added protection.
    Lookes to me like one switch pumps up both shocks at same time, and then you controll the lowering of the shocks seperatly, this true?
    Any tips or sugestios on the placement of the aircompressor?
    Any help would be great!!!![​IMG]
    Bigmeats
    Carl...75 Blazer...Manhattan IL
  2. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Its the same line as air shock line, I dont think you have to worry about it freezing. I routed the rear shock line in that black flex tubeing for extra protection. My shocks are also upside down so the air line is at the top and you dont need a long loop of it to move with the shock.
    I mounted my comprerssor to the fire wall. Yes you blow up all the shocks at the same time and if you have the duel controller, you can let down the front or rear set independently of the other.
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
    http://depdogsk5.coloradok5.com
  3. Bigmeats
    Jul 29, 2000
    523
    Manhattan IL
    Depdog what is the advantage of mounting them up side down?
    Bigmeats
  4. Bigmeats
    Jul 29, 2000
    523
    Manhattan IL
    Also how long did it take you to install the remote unit?
    Thanks,
    Bigmeats
  5. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Meats, I'm installing mine this weekend. (RS9000 dual incab remote that is) Install looks reallyyy simple. I'll do a write up of it after I'm done and post it on my website. I also mounted my shocks upside down like Deps. The only advantage I saw to that was it was easier for me to adjust the knob of the shock than the on the bottom. But that won't matter after the incab remote. Also another advantage I thought was it kept the knob out of harms way, like rocks and stuff when wheelin. Other than that, it the same deal. Anyways, I'll have the write up of the install by next week, if you want to wait, if not, good luck to you brother.
    Boss
    http://www.boss.coloradok5.com
  6. Bigmeats
    Jul 29, 2000
    523
    Manhattan IL
    Thanks Boss!
