another carb more problems
Discussion in 'The Garage' started by bryguy00b, Apr 7, 2004.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok i got the other carb but im still having problems it runs to lean or rich or something..it sounds like its desieling or something, and it doesnt seem to matter if the choke is closed or open..even though the choke doesnt seem to open all the way like it should. any one have any ideas? its spitting and sputtering out the tailpipes and making mild backfires and its just not right..i cant find any leaks
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Adjust the timing and lower the idle speed. Backfires are usually timing related. And dieseling is also timing related , but mostly idle is too high. Just got to play with it a bit until she purrs. I would back off the timing a hair and try it. /forums/images/graemlins/k5.gif
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i really dont think its the timing this thing ran fine with the other carb on there, just the floats kept sinking or something on it or something..and ive tryed adjusting the idel on it doesnt make a difference in how it runs, just the RPM of course, and i cant actually seem to find mixture screws on this thing, the spots were they would look to be are just little rounded of stud things..this is also a quadrajet by the way..
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I agree, sounds like timing needs to be adjusted.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Those things are the mixture screw. Originally there was a cap there so you couldn't touch them when new. Napa has a tool with a flexible shaft and some bits to fit those. Or you can find a small 1/4 drive socket that may turn it. /forums/images/graemlins/k5.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    99% of so-called problems are usually ignition related.
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    That I know, but when otherwise perfect and idle is high ,it will diesel. Timing is the first thing to check if it backfires. Been through all this until I found that perfect spot of truck driving and wheeling right /forums/images/graemlins/k5.gif
  8. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    by dieseling now, i dont mean runs after i turn it of, i mean it sounds wierd when its running, like it doesnt sound like a v8 at all..the more i think about it the more im thinking maybe it is ignition related..
  9. mogas
    mogas 1/2 ton status
    Apr 5, 2004
    118
    Flagstaff, AZ
    1-8-4-3-6-5-7-2 those are the magic numbers that I would check first.
  10. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    oh, there right unless someone poped the hood on me. it didnt runt like this till i swapped this carb on there. the other one it ran great expect for when the float would drop or something and cause it to flood out, but when it was fine it ran super..so its got to be carb related..im ganna take it of and have the dude give me another one hes got a bunch..
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Does sound like timing then. Does it sound like a ping ( like diesel truck acceleration ). If it is all the time , timing too far advanced. If it is only part throttle steady rpm cruise, it is too much vacuum advance, or octane too low, or gears to high. I would back off the timing and try it. You may also want to get an adjustable vacuum advance to help tune it in. Let us know how it goes /forums/images/graemlins/k5.gif
  12. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    but what i dont understand is why switching a carb would have an effect on the timing?
  13. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    When you switched did you install the vacuum advance on the right port? That could cause it to advance when it shouldn't. Perhaps the distributor was moved by accident if it wasn't tightened enough. Sometimes it happens, good plan is to double check timing anyway when you do any work like this. /forums/images/graemlins/k5.gif
  14. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    I would check all your vacuum connections again. This could be causing symptoms you describe. Is this a new carb?
  15. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ill have to take a pic of it and show u guys cause im not 100% that all hoses are were there suppost to go. but they are all blocked of if they are not being used. theres also that really big openning thats threaded on the back that both of my q-jets have, and i pluged that with a threaded plug and thread tape to..and no the carb is just a used one a guy had..so..god knows haha
  16. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The hose on the back of carb threaded is for power brakes, do you have manual brakes? Or are you hooked into manifold vacuum directly?
  17. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    its hooked into the manifold..yea its got power brakes lol and they do work so it must be and i think it is anyway
