Another carb question.
Discussion in 'The Garage' started by stump_puller, Jul 12, 2004.
  1. stump_puller
    stump_puller 1/2 ton status
    Apr 5, 2002
    871
    135
    Corbin, Kentucky
    /forums/images/graemlins/1zhelp.gifI done a search and good some good directions to go. But here is my problem. I just got the 350 going I'm having problems dialing in the carb. It is a elebrock 1406(electric choke 600cfm). I put on aelectric choke conversion kit and I also put in the offroad needles. Now it idles alright but when I put it in gear it bogs down then dies. I adjusted the mixture screws to achieve the maximum rpm and the maximum vacume. But that still doesn't seem to help /forums/images/graemlins/dunno.gif.
    You carb guys got any ideas? I would to get this thing up and running thats all I lack to get her on the road.
    I hooked the vacume gauge on the drivers side port that was capped off. If this is correct do I need to block off the distrubtor advance hose(like checking the timming).
    Thanks in advance,
    Don
    /forums/images/graemlins/waytogo.gif
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    You should hook up the guage to a manifold vacume port. Some of the ports on a carb dont give a true vacume reading.
    All other vacume lines should be either hooked up or plugged
  3. stump_puller
    Apr 5, 2002
    871
    135
    Corbin, Kentucky
    I'll try that. thanks.
